Results 1 to 10 of 17
Thread: Mini LCD Fault Display is faulty (in RPM gauge)
    Staffordshire
    Angry Mini LCD Fault Display is faulty (in RPM gauge)
    Hi all,
    Just noticed my 52 plate Vectra C LCD has gone a bit odd. I've uploaded a couple of photos. It is on every fault that it displays (i.e. door, light, service light).
    I'm guessing it will need replacing. Wondering if anyone knew how easy it is or if its possible to replace it. If it can be replaced, has anyone got the part no?
    If not, if I changed the whole instrument panel (RPM, Speed, fuel, LCD...etc.) I'm guessing it won't effect the car's odometer/mileage readout?
    Any ideas?
    Cheers,
    Rich.
    Regular Member Robward27's Avatar
    Witham
    Mine is exactly the same in the same place as well!
    Regular Member Edd's Avatar
    PSN: Daviebarnes
    mine has just done this too but more to the left can it be changed
    milton keynes
    Quote Originally Posted by Edd View Post
    I have tried to replace one of these , its not recommended. You will be far better looking on ebay for a new set of clocks. You should pick them up for about £40.
    PSN: Daviebarnes
    will my mileage stay the same if i change clocks
    milton keynes
    No , the mileage is recorded in the clocks. I was told that the ecu also holds this info on a full canbus , but have not been able to prove or disprove this yet.
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    There is a very old thread on here somewhere on this as well, bit they weren't replaced.
    The same happenned to me last year, very similar but what I found was after a while the corrupted bit of the display slowly corrected itself until the display was back to how it should be.
    Mine's been fine ever since so what caused it and why it would fix
    I have a theory that up to when it started to go like yours, I very rarely saw the door open indicator, however when I noticed the problem and as it slowly fixed, for various reasons I was more often dropping people off without swithcing the engine off - maybe some damp had got in and it dried out or something.
    If it's only just started happening I'd be inclined to leave it a few weeks and make sure that the door display is triggered frequently and see if it does just correct itself.
    Edit: Here is the thread I was thinking about.
    Last edited by MysteryElite; 15th March 2009 at 14:54. Reason: Added URL to old thread
    Mileage : 000
    It seems to be a sort of bleeding between the layers on the LCD. It is also becoming more common on the Vectra now. It would be nice if they do "self heal" though.
    Northampton, UK
    Quote Originally Posted by kman247 View Post
    That's strange! I was just wondering this yesterday! I even googled it LOL. I was trying to work out how a car knows LOL.
    Wales, UK
    Perhaps its just trying to say it might snow soon ? lol
  1. Faulty boost gauge..
    By Steven in forum Vectra C / Signum Troubleshooting
    Last Post: 15th April 2012, 21:34
  2. signum 2.0t coolant loss and faulty temp gauge
    By catbic in forum Engine & Drivetrain
    Last Post: 25th July 2011, 09:42
  3. faulty temp gauge ?
    By tractordriver28 in forum Engine & Drivetrain
    Last Post: 13th January 2009, 23:30
  4. Fault code 55 (Faulty ECU?). what to do?
    By sudiptabd2002 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd July 2008, 08:29
  5. Faulty Temp Gauge??
    By greg in forum Engine & Drivetrain
    Last Post: 3rd January 2007, 02:11
mini lcd vectra c
Tags for this Thread
