Thread: Vectra tailgate won't lock
    Durham
    Default Vectra tailgate won't lock
    Opened my tailgate today (04 Vectra C 5 door) and it won't lock shut, there is nothing in the way of it as I shut it, it just won't lock. If you press the button on the tailgate there is no motor sound, anyone got any ideas?
    I've looked at the manual to see if it is covered by a fuse but the manual says nothing so I've checked all fuses and they are fine.
    Help urgently needed, I've no way of locking the tailgate at all!!!!!
    Plymouth
    Check the locking mechanism it may of jammed open.
    either tap it or try to release the locking bar that should come across.
    Durham
    Quote Originally Posted by Diet1985 View Post
    I can push a screwdriver into the mechanism and it closes round behind the screwdriver but then releases as soon as the screwdriver is removed, the mechanism seems to move freely it just won't lock.
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    i am currently having the exact same problem, tried the same things (fuses & that the catch was in the correct position) but still nothing.
    anyone have any ideas?
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    sounds like it could be the latch it self
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    gonna have the trim off tomorrow & try & fix it. had a problem a while ago where i couldnt open it, you would occasionally hear the motor going but not enough to fully release the lock. took it all apart, cleaned the micro switch, put it all back together & its been working fine ever since, until yesterday. gonna check for fault codes tomorrow before taking stuff apart, might narrow it down a bit.
    Open the tailgate
    Beside the mechanism you will see rubber cover, or it may be missing
    Insert a long thin screwdriver
    This will reset the mechanism
    Replace the rubber cover
    Close the tailgate
    If this does not work the the lock solenoid has failed
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    quick update.
    had the trim off, lock out & micro switch out too. theres around 11 volts going to the micro switch & to pins 2 & 4 on the connector to the lock, which are the brown wire & brown/black (i think, may be brown/blue) wires when i press the micro switch, but no noise/action from the lock itself.
    when the lock is connected the boot, interior, number plate lights & boot open tell tale on the rev counter all light up & theres a chime when driving away, obviously warning that the boots open. when disconnected there is no warning that the boots open, the boot light doesnt work, but otherwise everythings normal, apart from the fact that the boot doesnt lock.
    so, does this sound like the lock itself is at fault?
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    couldnt be bothered fiddling around with it any more, stumped up £42 for a new lock, thats if anyones interested!
  1. Boot Lock no whirring noise and wont lock or open
    By meridianghost in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2012, 14:16
  2. Never mind lock up ya daughters, lock up ya vectras!
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2012, 21:45
  3. 2002 Vectra lOCK SET AND ECU
    By dragonuk2000 in forum Electrical & ICE (including SatNav)
    Last Post: 7th February 2010, 12:38
  4. Vectra hatch won't lock
    By SpooRancher in forum Bodywork & Interior
    Last Post: 3rd November 2008, 21:41
  5. Tailgate Lock - Help Please
    By neil1194 in forum Bodywork & Interior
    Last Post: 12th June 2008, 01:23
vectra c tailgate lock
Vectra c boot wont close
vectra c boot lock
vectra c tailgate microswitch voltage
vauxhall insignia rear boot wont open
vectra boot not locking
vauxhall vectra boot wont lock
boot lock tailgate disassembly vectra
tailgate lock central locking problem vectra c
vectra c boot lockndoesnt lock
vectra c boot not locking
bootlock wontooen vectra
insignia boot wont close
vauxhall vectra 04plate boot wont lock
53 plate vectra boot lock not working
vectra estate boot not locking
holden vectra boot lock
55 corsa boot wont shut
opel vectra c tailgate program
how to release a jammed boot on a vauxhall vectra
vectra backdoor lock
insignia boot lock wont close
my boot on vectra c is jammed open
vauxhall vectra c boot wont lock
holden vectra boot wont close
