Results 1 to 10 of 22
Thread: m tec side lights
    North Wales
    Default m tec side lights
    Just got some MTEC sidelight bulbs . Went ot fit them and looks like u need to take the bumper off as there is not much room.. has any body changed without taking bumper off ????
    Fitted heated washer jets today took about 20 mins easy mod cant realy feel the difference but we'll see when it gets cold .
    Regular Member arkhan78's Avatar
    Nov 2007
    Leeds
    craig
    its a bit tricky to get at the sidelights but no need to remove the bumper just get stuck in, twist your hand about and you'll be fine!
    for the passenger side you can unclip the washer bottle and move it to the side to make more room.
    also drivers side should be easy enough if not take the top off the air filter and move it to the side.
    hope this helps
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    No mate, its a pain if you've got sausage fingers but you'll be able to do it. Take it you still have the pre facelift in you profile. If you still cant do it pulling the airbox out will help but bumper off is deffo overkill.
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    i managed to change side lights without removing bumper
    just unplug the full beam connector makes it a bit easier to get to
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    As everyone says you dont need to take the bumper off and I have jumbo sausage fingers and managed it
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Undo the 2 screws on the top of the light then you can pull it forward a little. Gives a bit more room to move.. Move the airbox as well, easier than taking off the bumper
    11 Post(s)
    I just partially removed the airbox to change mine on the drivers side, and the screenwash filler bottle neck on the passenger side.
    Regular Member Stuarty's Avatar
    Aberdeenshire
    I removed the air box and at the other side if you pull the neck of the washer bottle it will pop out of the bottle its just held in with a rubber washer and a good push will pop it back on hth.
    North Wales
    all done i was looking at the rong wires haha i was tryin to pull the tilit adjuster out :S lmao
    Quote Originally Posted by craig-k View Post
  1. side lights and number plate lights
    By antowens in forum Electrical & ICE (including SatNav)
    Last Post: 13th September 2012, 19:59
  2. Led Side Lights Fitted & 2 Rear Fog Lights
    By wardy23 in forum Electrical & ICE (including SatNav)
    Last Post: 12th March 2012, 23:16
  3. led dash lights and side light running lights
    By fjaimo10 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2012, 21:21
  4. Brighter Lights for side lights, Vectra SRI150
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 23:50
  5. Philips bluevision h7 head lights & side lights brand new
    By davidlewis24 in forum Parts for sale
    Last Post: 19th March 2009, 22:42
