Thread: 2.2dti only revs to 2600 rpm- spanner light on
    bradford
    Default 2.2dti only revs to 2600 rpm- spanner light on
    hi every one
    ive just put new head on to my vectra sri 2.2 dti after other blew it self to bits ( bought the car nackered with suspect piston blow. )
    put new head on checked every thing as some one had messed with every thing as all was lose when started stripping.
    started car other night with no problems. then dropped from 4000 revs to 2600 as if is in limp mode thought was diesel so put 20 quid in fired up drove up road it was fine ,then after 1/4 of mile lost power would only rev to 2600 again with spanner light on
    think have problem with little electircal components where all vacum tubes go from the throttle bodys ?
    engine sounds sweet so it has to be some thing daft electrically
    can anyone help ?
    does anyone with a code reader live near cleckheaton,bradford who could call round will pay obvoiously
    thanks
    Regular Member poves's Avatar
    lancashire
    Check and clean the connection of the multiplug onto the airflow meter .
    bradford
    ok will try that m8 cheers have you had this problem ?
    lancashire
    Yes on a 2.2 sri diesel - wd40 is always good as well .
    EVERYWHERE
    Boost pressure sensor is also one to check and clean along with intercooler hoses.
    Also check out this thread.
    http://www.vectra-c.com/forum/showthread.php?t=61471
    bradford
    cheers m8 suspect so had a subaru which did that
    cheers will try
  1. 30000 revs spanner light .limp mode .vectra 2.0 dti 2004
    By davemander in forum Engine & Drivetrain
    Last Post: 19th February 2013, 00:07
  2. Reluctant start, revs dipping and car with spanner light
    By coldo in forum Engine & Drivetrain
    Last Post: 12th November 2012, 23:51
  3. Spanner light and loss of power at low revs
    By Marky in forum Engine & Drivetrain
    Last Post: 29th April 2010, 16:34
  4. Spanner light on at low revs.
    By arnie_barney in forum Vectra C / Signum Troubleshooting
    Last Post: 13th December 2009, 11:39
  5. Spanner light at low revs?
    By ChrisFox in forum Vectra C / Signum Troubleshooting
    Last Post: 11th September 2007, 19:11
spanner light opel vectra Sri 2.2 diesel
