Thread: help help please
    Regular Member tankman's Avatar
    Feb 2007
    NORTHUMBERLAND
    Default help help please
    HI GUY'S COULD ANYONE HELP IVE JUST BEEN OUT TO TAKE A FREIND SOMEWHERE AND ON THE WAY BACK HE FOLLOWING THINGS HAPPENED
    1 RADIO WENT OFF
    2 ABS LIGHT AND TC CONTROL LIGHT CAME ON
    3 STEERING SYMBOL WITH A ! LIGHT CAME ON AND STEERING WENT HEAVY
    4 FUEL LIGHT CAME ON BUTHAD HALF A TANK IN
    5 WIPERS STARTED JUDDERING
    WINDOWS DIDN'T WORK MIRRORS AS WELL
    FANS,HAZARDS ALL OFF
    NOW I PULLED OVER AND TURN ENGINE OFF AND THEN STARTED IT AGAIN BUT IT WAS DEAD LEFT IT 10 MINS AND IT FIRED UP NONE OFF THE ABOVE CAME ON UNTIL I DID HALF A MILE AND IT ALL STARTED AGAIN SO I CAME HOME AND TURNED IT OFF NOW IT WON'T START .PLEASE HELP IF ANYONE HAS ANY IDEA'S THX STEALERS WILL MAKE SMALL FORTUNE I BET
    OHI DRIVE A 2005 1.9CDTI SRI VECTRA 120
    May 2006
    n.ireland
    alternator and battery?, happened to me in my last veccy. Hope I am wrong though, It cost £740 to fix at the dealers, I got lucky with 90% good will as I got all my work done there, services etc and was only 2 months out of warranty. Good luck
    Feb 2007
    NORTHUMBERLAND
    thx m8 seen another thread about this problems think your right .ive found this on ebay take a look at this on ebay tell me what you think
    item no.260348120281 thx guys
    Regular Member davree's Avatar
    Warton
    Vehicle : Insignia
    Engine : 2.0 CDTI (160)
    Year : 2010
    Mileage : 26000
    Definately alternator!!
    This happened to me two days after Christmas, alternator wasn't charging at a high enough voltage.
    No probs once a new one was fitted.
    Not sure about that alternator on Ebay though!! The ad says retail of £495 (or something like that) It only cost £290 for the alternator on my 2.2i fitted from main VX dealer!!
    Good saving though if that is the genuine retail price!!
    Regular Member gromit's Avatar
    Cumbernauld
    Connect jump leads and that should start your car or charge the battery. Once its going get a volt meter and check if its charging. You will have to do a bit of fault finding before you start spending loads of money. You can get your alternator re-conditioned if its found faulty and save a few quid.
    Feb 2007
    NORTHUMBERLAND
    thx guy's changed the battery today and found it to start but the same lights came on the dash.oh the battery i took off was well shot no green marker and whte powder on top of the battery so i will check alternator 2mrw will let you guy's know thanks again
