Thread: Strange problem
    manchester, UK
    Default Strange problem
    my Vectra C SRI 2.2DTI runs fine but......
    when the car gets warm the oil warning like comes on BUT the light only comes on when the revs are low and then when the revs are back up the light goes off
    any idea problems?
    thanks in advance
    regards kev
    Full Member Big Sig's Avatar
    How old is the oil/how many miles has the car done. The light is an oil pressure light - if i am thinking of the right one - so its indicating low pressure at low revs which is when the oil pressure is at its lowest. May need a thicker oil/oil change or could be the start of the sensor failing/oil pump problem.
    Regular Member trickysvec's Avatar
    shropshire
    my cav sri did the same and it was the oil pump.i know its a different type of engine but the problem sounds the same
    manchester, UK
    we'll i've had the car serviced recently and was running fine then my break caliper seized up and changed that and then a few hundred miles later the oil like keeps comin up so i dont know what it is
    are you sure its the oil light and not a low brake fluid light?
    Ex-Staff Full Member Taffyopel's Avatar
    Oct 2007
    Horley, Surrey
    Think you might have found the problem Sig!
    Did you have one of those 'Ah ha' moments when you read about the caliper change?
    Snowman, you got your ears on?
    Quote Originally Posted by Taffyopel View Post
    Yeah I did! Although i am prepared to be wrong
    Also, check for a leak on the caliper you have been playing with, you might be loosing fluid.
  1. Strange problem.
    By Chad! in forum Engine & Drivetrain
    Last Post: 13th October 2011, 14:18
  2. Strange problem
    By Graeme in forum Bodywork & Interior
    Last Post: 19th March 2011, 15:22
  3. strange problem
    By darko2301 in forum Electrical & ICE (including SatNav)
    Last Post: 14th April 2009, 12:18
  4. strange problem, help please
    By adamjukes01 in forum Engine & Drivetrain
    Last Post: 26th January 2008, 21:55
  5. Very Strange Problem
    By Ben H in forum Electrical & ICE (including SatNav)
    Last Post: 23rd October 2006, 17:32
