Results 1 to 10 of 11
Thread: Passenger seat not moving STUCK !
    north lanarkshire
    Default Passenger seat not moving STUCK !
    Hi, wondering if anyone else has experienced this problem. Its stuck, pushed all the way back and will not move forward. Checked for item stuck in the runner, checked the handle cable, looks okay. Any ideas?
    Do I need to remove the seat to fix, is it possible to break the seat runner?
    Regular Member penfold2000's Avatar
    Apr 2008
    Kettering
    My passenger seat doesnt move also - although the handle to move it has no resistance at all - which makes me wonder if the cable has snapped - is this possible? and if so - is it an easy fix? (apart from taking the seat out of course)
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by penfold2000 View Post
    Your cable will have popped out of the handle mate, just like a bike cable. It just pops back in.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    unless theres a biro in the runner and you cant see it that is the most comon thing i see
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    happened on my last vec, cable popped out.
    Regular Member darko2301's Avatar
    Croatia
    i don't know if it can be fixed with seats still on, but removing the seat takes about 5 minutes! you have just 2 T50 screws, and once you unscrew them you simply take the seat out..
    if i were you i would take it out and fix that cable
    Regular Member davree's Avatar
    Warton
    Vehicle : Insignia
    Engine : 2.0 CDTI (160)
    Year : 2010
    Mileage : 26000
    Same with mine, cable popped out. I used a tie wrap to make sure it didn't come out again as it kept re-occuring!!
    Warton
    Vehicle : Insignia
    Year : 2010
    Mileage : 26000
    Quote Originally Posted by darko2301 View Post
    You don't need to take the seat out to fix it!!
    It's a two minute job!!
    Regular Member Ben999's Avatar
    Milton keynes
    Seems common, mine has popped out a couple of times. Can fix this quite easily without removing the seat
    York
    I have same problem. Can someone tell me how you pop it back in? I've tried and it just seems to come out again.
    Can you order a new cable from somewhere?
  1. Drivers Seat Back, moving appears loose
    By robster23 in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2013, 16:55
  2. Middle seat stuck up
    By kenno31 in forum Bodywork & Interior
    Last Post: 10th September 2011, 09:27
  3. Seat moving about on subframe
    By grumpano in forum Insignia car chat
    Last Post: 5th July 2010, 17:27
  4. Rear seat stuck down due to locked seat belt
    By Brad_The_Yid in forum Bodywork & Interior
    Last Post: 15th May 2010, 13:22
  5. stuck seat
    By aptoman in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2009, 19:13
