Results 1 to 10 of 11
Thread: Help cdti 150 won't rev
    Regular Member W17GLE's Avatar
    bolton
    Default Help cdti 150 won't rev
    Hi after a spirited run today the car lost all power and sounds like a tractor when revved. the car will not go above 2000 rpm and if you rev it with the bonnet up you can see white smoke over towards where the battery is. Is it the turbo that has gone or is it the manifold that has cracked? there is no smoke out the back of the car and there was no large white plumes either at anytime.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    egr valve is stuck open mate
    bolton
    how do i go about sorting this? i take it that it is nothing major then. I've just read through 40 pages of posts but still don't really understand it
    Got the haynes manual here would it be a case of replacing the valve or is it something you can service?
    bolton
    Took a look at the car today and the following pipe has split
    can some one please tell me what it is? and also would you think it would have caused any other major damage?
    bolton
    sorry about the very large pictures
    bolton
    Its the pipe that goes to the manifold and the egr valve any ideas of cost?
    Belfast
    Yep, that's the manifold to EGR pipe. Should be a cheap part and 4 bolts to change it out.
    bolton
    cheers mate at least now i know i'm looking along the right lines will that going have caused any other problems that you know of?
    Durham
    sound right to me as well
    Regular Member Drew's Avatar
    Sedgefield
    Don't run the car until you can get it fixed there are plastic parts (swirl flaps) in the inlet mainifold and you could distort them if the egr is stuck open. With the egr stuck open the engine is continuously recirculating hot exhaust gases into the inlet manifold.
  1. Weird noise from Signum CDTI 1.9 CDTI (150)
    By oneightycd in forum Diesel Engine related
    Last Post: 22nd June 2007, 22:27
  2. CDTi 120bhp Vs CDTi 150bp
    By bennyk in forum Diesel Engine related
    Last Post: 6th December 2006, 23:45
  3. CRD2 Tuning Box for V6 CDTi or 1.9 CDTi
    By The Doc in forum Parts for sale
    Last Post: 20th October 2006, 21:51
