Thread: Rear windscreen washer problems
    High Wycombe
    Default Rear windscreen washer problems
    No water is getting through to the rear window washer, is this common?
    Is it just likely to be a blockage?
    Wondering lonely as a cloud
    23 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Normally a blockage mine was in the front near side wheel arch I cut the pipe as it went under the scuttle and replaced it with new pipe using a cheap joint from Halfrauds and then cleaned out the original pipe and refitted it with the joint piece no need to remove the arch liner that way. I cut it there so as to avoid removing the hadling and bits of internals and it worked for me.
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Have a read of this thread mate, should sort it out.
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    pull the washer jet out of the aeriel carefully and the remove the black pipe from the jet and get a little compressor the type you put in a 12v point and put the end down the pipe then remove the cap under the bonnet of the washer bottle then switch the compressor on and hey presto after a couple of minutes the water will overflow out of the bottle under the bonnet and the blockage has gone!!! i did that and it works a treat now!!
  1. windscreen washer help
    By neill in forum Electrical & ICE (including SatNav)
    Last Post: 23rd May 2013, 08:56
  2. Windscreen washer
    By hadiislam in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2012, 21:33
  3. Windscreen washer
    By Alansvecky in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2011, 12:46
  4. Windscreen washer Bottle
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2010, 23:01
  5. Windscreen Washer Motor
    By cae2020 in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2007, 21:31
