Thread: Jammed passenger seat
    north lanarkshire
    Default Jammed passenger seat
    Hello,
    Hope someone can help, just got the car a few days ago. Its an '04 plate 1.8ls. The seat is jammed stuck, checked for coins, checked the known good drivers underneath with a torch to see how it all functions. The cable seems okay on both sides as the rod that turns the release mechanism seems to turn, the only thing I can see different on the seat that doesn't work is that it doesn't make contact with some sort of bolt stud thing that I can only assume is a part of the catch release mechanism.
    I don't understand the whole workings as this will be my first attempt at fixing anything car related. If anyone has had a similar problem in the past, then some advice would be much appreciated.
    Regular Member Zark's Avatar
    Herts
    what's it not doing? forward and back or the back rest tilt?
    north lanarkshire
    Its all the way back and won't move forward.
    Oct 2007
    Midlands, UK
    I also have this issue with my '07 Signum. Can't see how or why it's stuck !
    Shameless bump ^^^
    11 Post(s)
    Quote Originally Posted by daba View Post
    Surely the remainder of the 3 yr warranty will take care of it? Unless the car has done more than 60,000 miles or missed a service?
    Oct 2007
    Midlands, UK
    You're right, just thought if it was easy to release it I would save the hassle of booking it in.
    Although I think the EGR valve has started to play up now, just a little sluggish taking off until the revs get up.
    So I think a call to dealer in order.
  1. Front Passenger Seat Belt Jammed
    By smoggie in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2013, 16:28
  2. Always wet under the Passenger seat
    By akeem in forum Bodywork & Interior
    Last Post: 1st January 2013, 20:35
  3. passenger seat jammed right back on runners and wont budge!
    By richiem in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2011, 22:28
  4. Passenger front seat jammed
    By Darryl2.2DTI in forum Bodywork & Interior
    Last Post: 12th April 2008, 09:44
