Results 1 to 10 of 13
Thread: Car feels a bit pants?
    Regular Member chris_1d's Avatar
    Cambs
    Default Car feels a bit pants?
    My car seems to have lost a bit of power...I can't seem to get it to really go, it dosen't seem to have any torque...I go to overtake and it kind of feels like, do I have to...ARGH!!!
    And my clutch is creaking too! ARGH!!!
    Full Member Big Sig's Avatar
    If its under warranty get it in asap. I'm going to guess at stuck swirl flaps as it seems to give those types of problems
    Cambs
    I've booked it in with the dealer, although they are saying without a fault code/light they will struggle to find a problem! Grrrrr, only had the car 23 days!
    Nicking Ya Dinner.
    If you have a 1.8 it will feel like a slug after the Superb Chris, most popular cause of sluggy acceleration is the MAF, if there are no codes ask the dealer to swap one with another if they have one to eliminate it.
    Cambs
    Its the 1.9 CDTI 150bhp...should "feel" quicker than the Superb surely??
    Also, with the window down, there is a lot of turbo whistle when accelerating!! A lot!
    Regular Member Phil MC's Avatar
    Kirkie
    Default Possible EGR Valve defect?
    It sounds like the classic symptoms of an EGR Valve fault.
    I take it if you slip the clutch to get the revs up around 2-2.500rpm then the car accelerates ok and the turbo kicks in as it should?
    My SRi CDti 150 has just started doing this as well. It took a week or so for my EMS light to come on, and my local garage said the fault code was for the EGR Valve.
    I'm waiting on my replacement valve arriving (£45 incl P&P from ebay) and will change it out myself (Takes about 30 mins).
    If you do a search for "EGR" in this forum you'll find all the info you'll require .
    I guess you need to wait for the EMS light to come on so you can correctly diagnose the fault code first?
    Good luck,
    Phil
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    egr valve, i bet m8
    What revs are you trying to overtake at?
    Cambs
    Thanks for your replies guys,
    I thought EGR too after looking at the threads.
    I try and overtake between 2.5k and 4k revs, sometimes I get a rocket effect, others it just kind of thinks about it and overtakes leisurely...
    I would say 4.0K revs and above is too high for overtaking, you want to be between 2.0K and 2.5, that way you are at the lower end of the torque range and can use it to its full effect
    It may seem strange driving at 50mph in 6th gear, only changing down to 5th gear to overtake, but trust the engine and you will see the difference
    At a push change down to 4th gear, but there should be no need to go to 3rd gear or lower
  1. Jiz in ma pants
    By Keithy in forum Comedy & Humour
    Last Post: 25th October 2009, 23:55
  2. How this guy didn't cack his pants is beyond me!
    By Taffyopel in forum The 'Off Topic' room
    Last Post: 24th December 2008, 05:22
  3. Done the H1 & H7`s now the 5W5 look pants
    By PeterVV in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2008, 10:28
  4. Have I had my pants pulled down????
    By doilum2003 in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2007, 12:22
  5. my brakes are pants!
    By pogo in forum Suspension, Wheels & Brakes
    Last Post: 18th May 2007, 22:48
