Thread: Cruise Control
    Leeds, UK
    Thumbs up Cruise Control
    Hi all,
    I am having some trouble with my Cruise Control on a 54 Vectra CDTI SRI. I have replaced the clutch pedal spring and the indicator stalk (Both brand new parts) but it is still intermittent. This morning driving to work it engaged for 5 mins then just disengaged. When i tried to use it again it kept switching off straight away.
    On my way home from work it stayed on for the entire journey.
    I have tried pressing the clutch and brake pedals to see if the switches are set too close but you have to depress the pedals to switch it off.
    Does anyone have any ideas of what it may be or what i can check?
    Full Member Big Sig's Avatar
    Does it only switch off when going down a hill/long downhill gradient? If so mine does it every now and then. Not sure why.
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    Is there a switch above the clutch pedal that is not being depressed?
    Regular Member mattolly86's Avatar
    oxfordshire
    i had the same thing if you have a fault code appear it also drops cruise control i experenced this when i had a whole in my intercoller
    Leeds, UK
    Default Thanks for replies
    Hi all,
    Thanks for your replies. I will look at the switch above the clutch but I doubt that will be it as it switches on ok will last maybe 5 mins then go off.
    It doesn't seem to make a difference if i'm driving uphill / down hill. it does sometimes go off if i hit a bump in the road etc.
    I don't have any fault codes up at the moment.
    Thanks for your responses. If you can help me further i would appreciate it.
  1. Cruise Control
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 19:43
  2. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 21:14
  3. Cruise Control
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 12th May 2008, 17:36
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise Control not there?
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2007, 18:23
