Results 1 to 10 of 14
Thread: Fitting a towbar to a signum
    Regular Member eaglepva's Avatar
    Up North
    Default Fitting a towbar to a signum
    Hi can anybody tell me if i need to drill holes to fit a towbar onto my signum, i have the towbar and electrics (bosal). and is it easy?
    Or anybody know anybody who will fit it in the north east?
    Regular Member Figgz's Avatar
    Gothenburg - Sweden
    A very good how 2!
    http://www.opelsportclub.com/forums/...ad.php?t=52400
    It's in swedish, but the pictures are in english Yes, you need to drill holes to fit the towbar. 22mm holes iirc.
    Leicester
    You do have to drill holes, I have done two signums now.
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    As stated, it requires holes drilling to fit the 2 thickish load support plates which are fitted either side of the boot, which goes through the 2 main body members. You may also have to drill and grommet the rear of the boot for the cables, though you may be able to route them through the rear number plate grommet.
    Personally, for the small charge they make, I would have it fitted by someone like 'Towequipe'
    http://www.towequipe.co.uk/?gclid=CJ...FUob3godvx8PmQ
    My old 56 plated vec C also needed Tech-2 to enable the dash signal warning, and to disable car reversing lights etc. when the van was connected. Mine came with the VX towing kit already fitted, as I had ordered it when new, but VX had failed to Tech-2 it properly, and it had to be returned to the dealers to be done again.
    Up North
    Thanks for your help. it looks prety easy to fit.
    [Ex]Admin Duncan's Avatar
    From memory they are 30mm - but it should tell you in the instructions?
    Regular Member Robclowes's Avatar
    Oct 2007
    Crewe/Market Drayton
    Shame your not north west as I enjoyed fitting mine!!! I must be mad!!!
    Up North
    Got the instructions duncan but cant find the size drill bit required been to b & q but they aint got one.
    Anybody know of any mobile towbar fitters in the north east?
    You're not going to find a 30mm bit as such - you need the step bits type that start smaller and get larger - this kinda thing.... http://www.screwfix.com/prods/15976/...0DRILL-_-15976
    ..but obviously larger than that.
  1. Towbar fitting.
    By burbling1 in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2012, 16:59
  2. Towbar fitting
    By KTM Chris in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2012, 21:08
  3. Towbar fitting on a Signum
    By Andy R in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2009, 19:02
  4. towbar fitting
    By derby4life in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2009, 11:04
  5. fitting a signum towbar
    By BIG NEIL in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2007, 19:22
