Thread: Chipped Windscreen
    Full Member spennny's Avatar
    Blantyre
    Default Chipped Windscreen
    So Autoglass are here and they cant sort my windscreen, but spoke to someone last week and they were going to do it.
    How much is a windscreen these days or should i leave it till it cracks the length of the car. i use the motoroway Mon-Thurs
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Errm get that fixed mate can be dangerous if it does crack all the way
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    whats your windscreen excess id put a new one in with a nice top tint
    Blantyre
    Quote Originally Posted by Sean-2.2Direct View Post
    But he said he cant do it , Seems its been done before, and the resin hasnt set properly
    Blantyre
    Checking that now .................. £75 Quid
    Apr 2008
    Liverpool
    Fixed as in Replaced if it cant be fixed how big is the chip?
    you would probably be ok for a while but I would not leave it for a long time With the Cold weather and all it could easy turn in to a crack I had to get a chip done befor I went to france lucky I did as the Window was frozen solid
    Blantyre
    Guy is a ar5ehole - company man..... " Cant do it, i will get told off if it cracks later , i cant guarentee the job "
    I said well i wont tell if you wont, just do it please...........
    NO I CANT !!!!
    I will leave it, till it goes, then get a winscreen from somewhere
    Regular Member mark_w's Avatar
    cheshire
    there's one in my screen, a little bullet hole type one. i got autoglass to look at it, but similar thing, the guy said it had been done once. he said he could put a bit more resin in the hole as it wears away [?], just to make it look better and not wear the wiper blade. said replacement was the complete answer. i let him fill the hole a little and i just ignore it now, it hasn't got worse or anything.
    Blantyre
    Think i need to call that bloke Gavin from the advert on TV and tell him his work mates are ******s
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    to be honest the guy was probably covering his own back by not filling it again cause in a few weeks if all goes wrong who you going to call and complain to
    i wouldnt have filled it either if i thought it wasnt going to last and better to pay the £75 now than wait till it goes completely on the motorway doing 70mph and god knows what would happen
  1. CHIPPED UK RE-MAP DAY 24/06/06 (not 56k)
    By Robbieben in forum 2006
    Last Post: 12th August 2006, 19:38
  2. Chipped Uk Re-map 24/6/06
    By PIMM in forum 2006
    Last Post: 26th June 2006, 14:37
  3. Chipped UK 24/6/06
    By Spikey© in forum 2006
    Last Post: 26th June 2006, 08:08
