Results 1 to 10 of 17
Thread: Boost sensor on V6 CDTI...Where the hell is it?
    EVERYWHERE
    Default Boost sensor on V6 CDTI...Where the hell is it?
    Finally got DMF sorted and now 'turbo boost pressure sensor not within parameters' or some such code decides to rear its ugly head.
    I'm going to do the usual stuff before I decide to change the sensor (check for loose or split hoses,which seems favourite since the turbo was removed to do the DMF!),but I need to no where it is so that I can remove and clean it.
    it's screwed into the intake manifold, under the engine ECU..
    Beware thou.. cabby's started displaying this code before it had injector pump trouble..
    EVERYWHERE
    Isn't the ECU on the air box ? Or is it the one over the EGR ?
    I'm guessing it's the hoses,since they were taken off to do the DMF.No problems until then.
    Its a small grey sensor on the rear right of the engine under a load of cables and crap. Its got boost written on it IIRC. Remove the cover on the top and have a poke about.
    EVERYWHERE
    OK,thanks for that.Will have a look in the morning.
    EVERYWHERE
    I've just bought a boost pressure sensor off e-bay for a tenner! (how much are they new?)
    It may not be any good,but on the other hand..................
    EVERYWHERE
    Cleaned the sensor and all seems well after a little bit of 'spirited' driving.
    Nice result, mine was blocked up when I took it apart and the monkey that had fitted it had chopped the seal when he put it in!
    EVERYWHERE
    Goes really well now,and seems to boost much higher and for longer.
    It's a bit of a nightmare to get to.
    You've got to undo the black breather tube that runs across the top of the engine from left to right and unclip it from the turbo inlet.Then you've got to remove the device that sits above the sensor,just undo the top bolt and pull it away from the bottom rubber after you've disconnected the two black tubes from one end and the electrical cable from t'other.Be careful not to knock the air filter off it! Then unclip the tube that runs across the engine from back to front,so that you can get to the left hand bolt on the sensor.Remove bolts (still fiddly)and electrical cable,pull out sensor and clean.Refitting is reversal of removal.Job done.
    When I did mine I dropped one of the nuts somewhere in the vee, no idea where it went, it just vanished!
  1. 1.9 cdti boost sensor...read on!
    By bladeage1 in forum Engine & Drivetrain
    Last Post: 9th February 2013, 23:10
  2. cdti boost sensor
    By mike. in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2013, 17:16
  3. boost sensor 1.9 cdti
    By andy_hare in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2010, 16:21
  4. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
vectra v6 boost sensor
