Thread: Dash Lights always on - How to ? ? ? ?
    Regular Member NealM's Avatar
    Mar 2007
    Cheshire
    Vehicle : Pre-Facelift
    Trim : LS
    Engine : 1.8 Petrol
    Default Dash Lights always on - How to ? ? ? ?
    On the facelift the dash lights come on when you start the car and are permanently on. On a PRE facelift the dash lights only come on when you switch the lights on.
    Does anyone one know if it's possible to get pre facelift to have dash lights on all the time.... .. ...TECH2 ? ? ? ? Or can I take the instrument cluster out and make some changes to the circuit board, I'm not afraid of a bit of soldering.
    Any comments gratefully received
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    They will be controlled by the CIM module, and changes will be software not hardware.
    Mar 2007
    Cheshire
    Trim : LS
    Engine : 1.8 Petrol
    So are you confirming that it can deffo be done via TECH2 session ? ? ?
    [Ex]Admin Duncan's Avatar
    It all depends if the version of CIM in the pre-face can be programmed to do that. I suspect it won't be able to.
    Mar 2007
    Cheshire
    Trim : LS
    Engine : 1.8 Petrol
    That was what I suspected, that it WOULDN'T be possible via TECH2. . . . Does anyone know of a "hard wired" solution to this ? ??
    Oct 2006
    Wellingborough
    Put sidelights one whenever you start the car? or have tech2 to to always put sidelights on (should be possible with any car because of countries that require it)
  1. Dash lights
    By stuk2000 in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2013, 21:51
  2. led dash lights and side light running lights
    By fjaimo10 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2012, 21:21
  3. Dash lights
    By VECTRA HEAD in forum Electrical & ICE (including SatNav)
    Last Post: 29th December 2010, 22:42
  4. Dash Lights???
    By dave04 in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2010, 15:32
  5. Dash lights?
    By Messenger in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2009, 21:29
