Thread: Are they the same bits?
    birmingham
    Default Are they the same bits?
    hi guys,
    can anyone tell me if the Fuel Regulator is the same as the Swirl Actuator?
    anyone watch 'Watchdog' about dodgy Vectra's The 2.2 Direct models (Z22YH)
    http://www.bbc.co.uk/blogs/watchdog/...ll_update.html
    cheers all
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    No mate. The swirl Actuator is part of the inlet manifold. It control the air speed in the runners. And yes that system is prone to failure in the direct as well.
    birmingham
    ...thanks Rushy..
    if the Swirl Actuator fails, how much should i expect to fork out? or better still can you point me in the direction where i can get my mits on 1, 2, or 3???? what else comes with the deal?
    where do the problems end???? Arghh
    Vehicle : SRi
    Mileage : 137000
    You need a hole new manifold I believe. Not cheep. Its the same system as on the CDTi's I think, different part but same type of thing.
    Regular Member Drew's Avatar
    Sedgefield
    I have a 1.9 16vCDTI i paid a total of £382.00 at the dealers for a new manifold and actuator plus gaskets. i then had to get it fitted and that wasn't the end of the problems.
    birmingham
    Quote Originally Posted by Drew View Post
    OMG!! what else brewed up?
    besides going back to the dealers, is there anywhere else i can buy the kit? vauxparts?
    Vehicle : SRi
    Mileage : 137000
    No kit mate, new manifold. Basically there is a little motor that moves a linkage that in turn moves the "flaps". I believe the idea is thinner runners for faster air for better low down torque, larger greater volume moving runners for top end power. The ECU controls the hole lot depending on engine revs and load.
    birmingham
    Thanks for info Rushy..i'll try and explain that to my mate in the garage..
    do u have a contact where i can buy the parts?
    Vehicle : SRi
    Mileage : 137000
    The only place I would try would be Autovaux other than the dealer. I'm presuming its a Genuine VX part only.
  1. my sri still got bits to do
    By veccy c in forum Quick Photo Album
    Last Post: 30th June 2012, 13:41
  2. For Sale: few bits
    By paul.sessions in forum Parts for sale
    Last Post: 27th June 2011, 20:36
