Results 1 to 10 of 15
Thread: Brake bleed sequence
    Chelmsford
    Default Brake bleed sequence
    Hi folk,
    Changing my pads and fluid tomorrow morning. Annoyingly I've forgotten my Haynes book.
    I'm using a pressure bleed kit and have done the job loads of times on various other cars, but not on the vec. Anything special need thinking about when bleeding the system on the C?
    Can someone please remind me what the bleed sequence is. I think it's rear left, front right, rear right, front left, clutch, but I'm not 100% sure.
    Cheers.
    Regular Member Craig1985's Avatar
    harwich essex
    I THINK its NSR OSF OSR NSF sure someone will confirm
    [Ex]Admin Duncan's Avatar
    Why are you bleeding the clutch if you're only changing the pads and brake fluid?
    Re bleed sequence. Can't remember the particular order, other than you start furthest from the master cylinder - lemme check something.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    From Haynes - rear left, front right, rear right and finally, front left.
    Oh, and try and use a pressure bleeder http://www.gunson.co.uk/item.aspx?cat=664&item=1818 (as Parsco on here has found out LOL).
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    here is one half the price nealy m8 ...i think im a ebay junky lol
    http://cgi.ebay.co.uk/Gunson-Eezible...1%7C240%3A1318
    There we go, beat me to it. I knew it was one of the rears first as you start further from the master cylinder, but couldn't recall what side! End of the day it's not overlay critical - you can bleed them in almost any order, you just may end up using more brake fluid to push it all through.
    The Eezibleed is definitely recommended.
    Regular Member Jackvectra18's Avatar
    Winchester
    Im only an apprentice atm but i have always been taught to start at the furthest away from the reservouir and work back, i dont know if that makes any difference??
    Ashington, Northumberland
    Best practice is normally to go furthest from Master Cyl first, working to nearest to MC. On some split systems, it is best to bleed diagonally paired wheels one after the other. Ie if it is a n/s/f and o/s/r, o/s/f and n/s/r diagonal split, then it is best to go furthest away from MC, then straight to it's diagonal partner. Then do the remaining two. Dunno if that makes sense lol. I know what I mean lol
    EDIT; Just as Jack said lol
    On a Sabbatical daviek's Avatar
    ayrshire scotland
    Quote Originally Posted by Jackvectra18 View Post
    Yep thats what I have always done buddy
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Well done Jack, spot on always bleed futhest from resevoir first, then other rear, then diagonal to the front, finishing with the nearest wheel to the resevoir
    3.2 v6 Signum and loving it
  1. Brake bleed sequence
    By mungo1985 in forum Suspension, Wheels & Brakes
    Last Post: 5th January 2012, 16:14
  2. Full brake bleed
    By DNS in forum Vectra C / Signum Troubleshooting
    Last Post: 24th June 2011, 20:06
  3. Rear brake caliper bleed nipple
    By tony_b in forum Suspension, Wheels & Brakes
    Last Post: 9th March 2011, 18:45
  4. Brake bleed problem? on new upgrade.
    By dv8 in forum Suspension, Wheels & Brakes
    Last Post: 15th September 2008, 16:33
  5. Brake and Clutch bleed
    By GoldenWonder in forum Suspension, Wheels & Brakes
    Last Post: 11th September 2008, 20:21
vectra c brake bleeding sequence
vauxhall vectra c brake bleeding sequence
what is the sequence for bleeding brakes on a Vauxhall Vectra
right order bleed vectra c brakesvectra c bleed brakesvectra cdti brake bleeding orderis there an order to bleed vectra c brakeswhat seqeucne to bleeding brakes on vectra c 3.2 v6how do i bleed brakes on vectra c 3.2 v6zafira b brake bleed sequencezafira brake bleed sequencezafira b brake bleeding sequancevectra c brake bleeding order
