Thread: Aircon light on when its not!
    Regular Member PORKBALLS29's Avatar
    Epping
    confused Aircon light on when its not!
    when i started my Signum tonight to leave work i noticed that the light on the air con button was lit. Which was strange as i've not used it since buying the car in november. I pushed it to turn it off but no go. And i noticed the revs rise slightly as if i turned it on. I pushed it again, light still lit but revs drop back to normal idle speed as if it had turned off again. I turned ignition off and back on after a couple of mins but light came back on with ignition. Does any body have any ideas?
    Regular Member Avenged's Avatar
    Liverpool
    gremlins??
    Regular Member s0501291's Avatar
    Warrington
    Not entirely sure but, I would guess possibley that the air con switch is broken (the contacts within the switch which supply power to the LED) OR possibley a stuck relay. If its just started randomley (like you say youve not touched it since you bought it) then possibley a cable within the control panel. Not sure how "sealed up" those control panels are, dont know if you can service just the air con switch or if its an entire new panel needed.
    Bottom line, it it was me I would be checking any relays in the fuse box to do with air con, maybe remove and re-seat them to make sure they have a sound connection. If it is just the LED thats constantly on, then not a huge problem, especally if the air con still actually works
    Hope thats of 'some' use
    Pete
    Epping
    cheers pete. Tried all relays/fuses today and all ok but light still on. It did go off momentarilly as driving this morning but came back on again a short time after. I was wondering if it was a warning saying air con needs regasing, but looked through manual and nothing in there about it. Does any body else have any ideas?
    Nicking Ya Dinner.
    Is it lit, or lit only when the lights are on?
    Epping
    its lit as soon as ignition comes on. It flickered on and off tonight and then stayed on again.
  1. Aircon problems - Not working, if anything air gets hotter turning on aircon???
    By Coupe2T in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 10:13
  2. aircon
    By Darren68 in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2011, 09:13
  3. can aircon problem put eml light on?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2010, 20:39
  4. Aircon
    By Sean-2.2Direct in forum Bodywork & Interior
    Last Post: 27th November 2008, 19:04
  5. Change aircon to auto-aircon?
    By um20 in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2007, 22:12
