Thread: Cam shaft oil seal leak
    South Yorks
    Default Cam shaft oil seal leak
    I have an 20mth old Veccy with 18k miles - dealer has had three attempts at fixing what was originally a bad oil leak which appeared to be coming from behind cam belt casing. After third attempt at 7k miles leak seemed to have been fixed, but after a further 11k miles there is now a film of oil on back of cam belt housing again (which reappears after cleaning) - so it looks like seal might be starting to fail again.
    Has anyone else encountered this problem ?
    Does it pose a risk, contaminating cam belt and causing premature failure ?
    Any comments welcome.
    [Ex]Admin Duncan's Avatar
    What engine?
    Belfast
    If it's the 1.8VVT there's a recall for that, to fit a modified cam cover seal.
    Mine, on the other hand has a leak in the crankshaft oil seal, in next Tuesday for repair.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Makes a mess and looses oil. The belt should be made of a material that is tolerant to oil (my professional opinion, but not sure if it actually is), Oil loss and mess would be my main concerns, along with the annoyance factor.
    I would keep badgering the dealer to fix, else they might suddenly say that it's not covered by warranty anymore. Maybe a different dealer may be better at it?
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    lets hope the oil does not get on the belt and make it slip or jump the teeth, not a nice sight
    i would try another dealers m8
    Belfast
    It's not the belt itself, it's the tensioner that gives the problem with oil - something to do with the bearing having grease in it and the oil washes it out? Sounds a reasonable explanation to me.
    As I said mine has a crank oil seal gone, it's flinging oil everywhere. They're replacing the seal, the belt, tensioner and something else I couldn't quite read upside down off the work sheet. Also insisted they steamclean the engine.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Unlikely to get onto the toothed timing belt, as the cover is quite close, so small amounts of leaked oil really shouldn't get in. I was more on about the ribbed auxillary belt
    South Yorks
    Sorry forgot to mention its the 1.8 engine - interesting to know its the suject to a recall - I'll check with the dealer if I've had the required work done.
    Thanks for your comments it gives me a more comfortable feeling that my cambelts not likely top give up.
  1. gearbox drive shaft seal
    By vectraross in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2012, 20:15
  2. 2.0T oil leak, poss crank seal or sump seal?
    By mann3210 in forum Engine & Drivetrain
    Last Post: 3rd March 2012, 11:11
  3. drive shaft oil seal replacement
    By skydivepaul in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2011, 13:15
  4. Oil leak from o/s drive shaft seal
    By olid2002 in forum Engine & Drivetrain
    Last Post: 21st March 2011, 23:51
  5. Crank Shaft Oil Seal !!!! PLEASE HELP!
    By s0501291 in forum Engine & Drivetrain
    Last Post: 24th April 2009, 19:53
