Results 1 to 10 of 11
Thread: Changing rear brake pads
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Default Changing rear brake pads
    Do you need to have a brake rewind tool or can you use somthing else need to know as im doing them tonight?
    Regular Member 12RM's Avatar
    Jan 2008
    Scotland
    I did mine by hand - long nosed pliers helped and it was a straightforward job.
    Apr 2008
    Liverpool
    Quote Originally Posted by 12RM View Post
    Ahh ok do you push the it in as well as turn clockwise at the same time mate?
    [Ex]Admin Duncan's Avatar
    You need to push in carefully and turn at the same time or you risk knackering the fine thread. I got a rewind tool as I didn't want to take the risk and knew I'd be changing at least a few seats of rears.
    Apr 2008
    Liverpool
    I can pick one up tonight like but just did not want to spend cash if the need was not really there.
    also how far do you wind it back how many turns?
    If you see yourself having the car long enough to do more rear pad changes, then I'd say it's worth getting the tool. If you do, make sure you get the right adapter for the brakes on our cars. Places sell the Laser tool but often don't have the correct adapter with the pins the right distance apart.
    You wind it in until it stops basically.
    Apr 2008
    Liverpool
    Nice one mate I will have the car along time so think i will invest in one will have alook tonight.
    Cheers should not be to hard haha im confident enough
    Apr 2008
    Liverpool
    one other thing will i have to leave the hand brake off?
    once done pump the brake pedal then pull the hand brake?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Not difficult to do with a small G clamp and something to turn the piston. I used a large bolt with 2 pins welded on the head between the G clamp and the piston. G clamp applies pushing force and a spanner of the bolt head turns the piston. Piece of cake, and easy to do both movements on your own as you can feel it.
    Move them in all the way until they stop moving in....
    I left the handbrake off, changed pads on both sides, and then pressed foot pedal a few times to bring the pads in, and then 'worked' the handbrake a few times.
    Apr 2008
    Liverpool
    Nice one see Do you leave the brake fluid top off?
  1. rear pads ready for changing?
    By ks246 in forum Suspension, Wheels & Brakes
    Last Post: 2nd June 2009, 19:06
  2. Changing brake pads
    By Sean-2.2Direct in forum Suspension, Wheels & Brakes
    Last Post: 26th November 2008, 17:58
  3. Changing brake pads
    By dutluk2001 in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2008, 21:06
