Thread: Watchdog - Engine Management issue
    Cheadle
    Default Watchdog - Engine Management issue
    Thanks for bringing this watchdog report to my attention:
    Although the report concentrated on 2.2 petrol models I note that other models seem to suffer the same problem.
    I drive a 1.9 diesel Vectra - and have had to suffer 'limp home mode' on a number of occasions since last August and I note that it seems to be a regular complaint on this forum.
    Is this the same problem that is affecting the 2.2 petrols or is it somehow less serious?
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    There are various other possibilities for the management light on a 1.9CDTI - you're best bet is to get the fault codes read to determine the cause.
    The #3 injector loom is a known issue on the 1.9 that could cause that.
    Belfast
    Along with DPF, EGR, swirl valves...
    The 2.2 Direct is probably the more reliable of the mainstream Vectra engines (I'm not counting the V6 or 2.0T). The 1.8 is probably the most reliable.
    Cheadle
    My point is really, is there a long standing fault with the components identified in the watchdog report on more than just the 2.2 petrol models?
    Jun 2006
    Somewhere...
    Not really. I thought the supposed issue on Watchdog was more to do with the fuel that had been used?
    Jul 2006
    I thought it was to do with the fuel pump...
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Fuel pump and fuel pressure regulator. These will be different to the one's on diesel. so wouldn't worry about those issues affecting you.
    Quote Originally Posted by Shadrack View Post
    No basically - the Watchdog report was specific to the 2.2 engine.
  1. engine management
    By crazyvectra2013 in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2013, 21:48
  2. Engine management light issue
    By Daz333 in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2012, 11:57
  3. Engine lumpy now Engine Management Light is on
    By Fitzy-2.0T in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2012, 16:51
  4. Engine Management Light Issue
    By bervie_lad in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 22:28
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
