Thread: alternator problems
    Mar 2007
    dublin
    Default alternator problems
    Hi all
    This evening while driving the spanner light and battery light came on, car was not in limp mode and drove home fine I checked the voltage across the battery terminals and got 11.8v which im thinking is a bit low, the battery light seems to come on after switching on the lights, heater fan etc, what do I need to replace and is the alternator hard to remove?
    thanks in advance
    East Midlands
    ??Did you check the voltage with the engine running..it should push out about 14,5 volts with everything switced on...if not sounds like the voltage regulator on alternators caput.
    Mar 2007
    dublin
    Yeah checked it with everything running getting a steady 11.4v not good is the alternator a pig to get out and is it easily fixed?
    cheers
    East Midlands
    Quote Originally Posted by bran.c View Post
    cheers
    Not easy to get at no ,but can be done if you are half decent with the spaners.sounds like you will have to swap the old one for a recon one.
    Regular Member davree's Avatar
    Warton
    Vehicle : Insignia
    Engine : 2.0 CDTI (160)
    Year : 2010
    Mileage : 26000
    I Know its probably not much help but I hust had my alternator changed by VX on my 2.2i, it cost £290 - £195 for the alternator and £95 labour. T
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    one for sale on ebay brand new £150.... sorry cant do linky thing but item no is 260348120281
  1. Alternator Problems
    By scottc in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2012, 16:22
  2. alternator problems
    By tyler boy in forum Electrical & ICE (including SatNav)
    Last Post: 10th November 2011, 19:19
  3. alternator problems
    By webtrawler in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2011, 08:09
  4. Alternator problems??
    By chrisvectra in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2011, 12:05
  5. Alternator problems
    By AJA in forum Electrical & ICE (including SatNav)
    Last Post: 27th August 2006, 07:58
