Results 1 to 10 of 20
Thread: ABS problem
    Edinburgh
    Angry ABS problem
    About 10 months ago locked wheels in ice, ABS kicked in and worked fine. The abs light then remained on. Tech2 stated problem with n/s hub so pal fitted new hub. Light stayed off for 2 days then came on again. Wiggled the sensor wire behind hub and light stayed off for 10 months, abs worked fine (braking on gravel etc.) ABS light back on, no amount of fiddling with wire will get it to go out. Reluctant to fit new hub as I do not think there was anything wrong with the first one.
    Anyone go any suggestions?
    Regular Member bgm46's Avatar
    South Queensferry
    If you wiggled the cable and the light stayed off for 10 months i would assume the cable is now damaged/broken cable or the plug is damaged
    lanarkshire
    is there a how to check the hubs and abs sensor ?
    Edinburgh
    My wife just informed me that light came off after she locked up on the ice the other day. So it seems that the activation of the abs has resulted in it malfunction?
    If it was just he ice then it would correct itself on a restart. It could be the sensor that has a brokn wire in it, the sensors are only available with a new hub IIRC
    Middlesex
    Quote Originally Posted by iceeee View Post
    I would also like to know this, anyone know??
    Regular Member Hs2300's Avatar
    yorkshire
    Check the sensor resistance using a multi meter on Ohms sholud be around 120ohms. Disconnect the sensor plug with the Ignition off and connect the meter probes to the terminals in the sensor end of the plug. place one probe in one terminal and the other probe in the other one (dosent matter which way round you connect them)
    Edinburgh
    Checked the resistance, reading zero. So faulty sensor or dirty sensor, hopefully dirty, as hub has only been fitted for 10 months. Is it possible to clean sensor without taking hub apart e.g. spraying with WD40?
    Any suggestions welcome as MOT due next month.
    lanarkshire
    would think if no resistance the sensor is open circuit. so no cleaning would,nt help probably new hub required not got round to checking mine yet
    and cheers for the resistance value Hs2300
    dont know if sensor can be replaced only. maybe some one can advise on that
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Would the hub be under warranty as its less than 12 months old?
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
