Results 1 to 10 of 23
Thread: Help with sourcing a Diesel Particulate Filter
    Regular Member Drew's Avatar
    Sedgefield
    Vehicle : 2017 Insignia ST
    Trim : Sri nav vx line
    Engine : 2.0 TD 170 auto
    Year : 2017
    Angry Help with sourcing a Diesel Particulate Filter
    I have just spent a load of time and money replacing the inlet manifold (worn out swirl flaps) EGR valve (siezed and despite cleaning and WD50 still wouldn't work) and while I was on Timing belt etc. Now with the top end fixed the exhaust has blown itself into bits and I need a new front pipe and Diesel Particulate Filter. My car as you will have guessed by now is a 1.9 CDTI 150 SRI Estate You have to laugh on the most depressing day of the year (and that's official).
    VX are quoting £1171.28 for the front pipe and DPF.
    Has any one found these parts cheaper or does anyone know if you can remove the DPF and just stick a bit of straight through pipe in. I don't fly so my carbon footprint is already very low .
    Drew, (sick as a turkey on thanksgiving)
    Regular Member parapaul's Avatar
    Jul 2006
    holy st! I think your best bet is going to be a breakers' yard, AFAIK there's no way to remove a DPF from a running car that should have one.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Is there any sensors on it? Maybe a pressure sensor?
    Sedgefield
    Year : 2017
    I think so it can measure a pressure differntial across it on the diagnostics so I guess it has
    Yikes! I know it wasn't well when we meet at the NE meet, but what's caused the exhaust to blow itself to bits?
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    If you could fool the ECM into thinking the (present) DPF didn't need a regen then you could fit a straight through pipe, safely in the knowledge that an active regen won't happen......
    I'm not saying you should, but the possibility is there.
    Mar 2006
    Nicking Ya Dinner.
    Better call Mark, he'll know if you can bypass the lot.
    Feb 2008
    space
    sorry but does your glow plug light keep flashing as i have the same model as you
    Sedgefield
    Year : 2017
    Duncan, I was suspecting it might be choked but had my fingers crossed it would regenerate its self once the other bits were fixed. It ran like a dream the day after the manifold was fixed but then back to being bad the day after. I checked the egr and that was goosed, tried to get it working but it kept going into limp mode. 2 miles from the dealers after picking up the new egr the car stopped, no power, I replced the egr on the road side fired it up and the exhaust blew apart. Don't know why but I can't stop laughing.....
  1. Diesel Particulate Filter
    By bafoo in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2011, 18:06
  2. Diesel Particulate Filter Re-gen
    By RobertHayman in forum Engine & Drivetrain
    Last Post: 16th November 2010, 23:47
  3. Diesel Particulate Filter or not??
    By Drew in forum Engine & Drivetrain
    Last Post: 26th January 2009, 09:32
  4. Diesel Particulate Filter
    By Eddie Dee in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2007, 20:10
  5. Diesel Particulate Filter
    By VectraV6CDTi in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2006, 09:16
