Results 1 to 10 of 17
Thread: Discs and pads (front and rear)
    Regular Member monkeez's Avatar
    Apr 2008
    North East
    Default Discs and pads (front and rear)
    Am i right in thinking that the best and cheapest place to get the above from is the stealers?
    I'm sure i've seen this mentioned on here before.
    Also the same place for ARB bushes?
    cheers
    Merseyside
    Think my rears need doing, so any help would be appreciated by me too!
    [Ex]Admin Duncan's Avatar
    You can get front and back brake kits from the dealers for around £65 + VAT (£45 odd + VAT if you have Trade Club access). That's for discs and pads. Pads are what are called aftermarket ones so not quite as good as the OEM ones (what came on the car) - but you can buy those additionally and still have got it all for a decent price. If your driving is fairly average then the aftermarket ones will be fine. If it's more spirited/got any added power then you may want to consider the OEM ones.
    Regular Member mark_w's Avatar
    cheshire
    i'm sure it's been discussed here many times, but is it basically pretty simple to do the rear discs/pads? [my discs have a bit of a lip on them, so i can see they won't last forever]. do the caliper bolts come out relatively easily? do you need a special tool to wind the pistons back in?
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    5 Post(s)
    Trim : GSi
    Mileage : 190,000
    What about for a GSi? I think my fronts need attention. Any ideas?
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Mark - there are How 2's on here for both front and backs. Yes, a wind-in tool is advised for the rears, although some people have chanced it and not used one. I wouldn't personally.
    GSiFan - what do you mean? If you mean brake kits then as per my reply above.
    cheshire
    thanks Duncan.
    Belfast
    I always use Apec pads, I get them from the motorfactors down the road. They're normally £20 a set. That's £40 for back and front.
    When I need discs I use QH ones from the same place, they're normally around £40 as well.
    Apr 2008
    North East
    What about Mintex discs & pads?
    I remember someone recommending them to me a while back.
    Jan 2006
    Skynet HQ EMEC#5
    I have ferodo premier pads on the front at the moment, they seem a decent pad, and lasting quite well.
    I've also got ferodo ones for the rear to go on when the time comes (which could be soon).
  1. new front and rear discs and pads
    By davidjameswest in forum General Chat
    Last Post: 13th May 2009, 00:17
  2. Replacement rear and front discs and pads
    By mcmcnaughties in forum Suspension, Wheels & Brakes
    Last Post: 5th May 2009, 14:31
  3. Front and rear discs/pads, cheap!
    By RocketRuss in forum Parts for sale
    Last Post: 16th March 2009, 18:30
  4. discs , pads front and rear
    By The Gas Man in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 27th February 2009, 22:42
  5. Mintex Front Pads, Rear Pads and Rear Discs
    By The Gas Man in forum Parts for sale
    Last Post: 6th January 2008, 00:34
