Results 1 to 10 of 16
Thread: Pre Heating System??
    Default Pre Heating System??
    Hi All,
    I'm new to the forum and looking for advice - i've done a few searches but can't seem to find what i need.
    After about 4 weeks of owning the car (2.0 DTi 04) with no problems the spanner light come on, on Christmas day .
    It comes on and then goes off once the engine has been running for a few seconds. It only happens when the engine is cold. If it has a little heat in it the light doesn't come on, so from what i've read could this be the pre-heating system??
    Any advice on what i can do to resolve this one (without getting the codes read)? Another thread specified cleaning the boost sensor may work for this fault, but not sure where this would be on the 2.0dti?
    Thanks,
    David
    Jul 2006
    Sounds like it's just a stored fault code, TBH. If the light goes out it's nothing to worry about
    If it was a stored fault code wouldn't it appear everytime?
    It doesn't seem to effect performance / consumption etc, but if it was a stored code i thought it would disappear after x amount of starts?
    Just think it's odd how it only comes on when the engine is stone cold
    Cheers,
    David
    stockton
    I had the same thing on my 1.9 turned out to be one of the glowplugs was down.
    hence the only happening when it's cold.
    changed them and it's not happened since.
    Andy
    Administrator plasma's Avatar
    On the Forum
    548 Post(s)
    Engine : 150
    Mileage : 74000
    agree with the above, you'll have one or more defective glow plugs causing this problem.
    Thanks for the replies - i just need to find some now.
    I've tried a couple of web-sites i normally use including buy parts by but can't seem to find any.
    Could anyone post a link to where i can get a good quality set from?
    stockton
    autoparts in thornaby will have them or electrodesiel over on portrack behind the new asda
    Andy
    I've phoned a couple of places and they have specified that there are two engine codes for my Vectra??? I've checked the documentation I've got with the car but it doesn't specifiy which it is - I've also had a look under the bonnet but can't find it stamped anywhere either.
    Can anyone help me on this one, it's a 2004 2.0DTi LS Vectra - I've been told the engine code could be Y20DTH / X20DTH - or am I going to have to contact Vauxhall?
    Cheers,
    David
    West
    Just to agree with the above the eml on just after start up on a cold DTi is deffo telling you the glow plugs are in need of changing.
    Why not give your local VX dealer a ring & give them the reg plate, they will tell you exactly which you need & to be honest they're not that much dearer from the dealer either.
    just take care when replacing them, a snapped plug is a head off job...
    hth
    stockton
    ring Vauxhall
    im sure mine was listed on the security card along with the stero code
    the other solution would be to pull a plug out and see what the code printed on it is as this will be the plug model and just give them that ? it's what i did since they had the wrong plug listed for my car
  1. Central Heating System Cleansing using Fernox Stuff - Help Please
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 4th February 2013, 10:32
  2. Help bleeding the heating system on vectra c 1.8 ls
    By 0114NIGEL0114 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th November 2010, 00:34
  3. Heating temperature control not working - Full heating permanently
    By jratcliffe3 in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2010, 23:46
  4. Signum Heating System Problem
    By Lotus_c_man in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2009, 14:04
  5. sludge in central heating system
    By moorlander in forum The 'Off Topic' room
    Last Post: 27th September 2008, 08:06
vectra c pre heating problem
