Thread: Idle problem
    Ex-Staff Full Member Spelly's Avatar
    Derbyshire
    6 Post(s)
    Default Idle problem
    My Gsi has recently developed and unusual idle problem.....
    Idles fine when started from cold but after ive drove 10 miles or so and the engine is up to temp the idle is up / down
    If i pull up to junction in neutral the revs drop to 750 ish then slowly increase upto 1500ish and then drop off again to 750
    the car is otherwise fine. I have removed the throttle body assembly and checked / cleaned it and all seems ok
    Anyone any suggestions as to where i start
    Thanks in advance.......................
    Regular Member poves's Avatar
    lancashire
    I think this is common , some people have ended up getting new or second hand throttle bodies from what I remember .
    Have you checked/cleaned the idle control valve?
    Regular Member 900ss's Avatar
    May 2008
    Bucks
    Should you need one I've a tbh from a sub 35k GSI
    Looks mint for what it is, tho not sure of price mind.
    Derbyshire
    6 Post(s)
    I have stripped and checked the ICV / Throttle body twice with no luck
    I have operated it with the throttle body plugged in but not attached to the car (sat on top of the inlet) and it seems to operate ok
    Reluctant to replace it as it may not cure the problem
    Bet they're expensive too.............
    lancashire
    I sold mine for £50 from a 41000 mile elite , as a rough guide on cost .
    The chap who bought it had the same symptoms as you describe.
    Regular Member s0501291's Avatar
    Warrington
    If the idle keeps rising and falling, sounds like some sort of vaccume leak. Have you checked all the hoses? (I had a 1.8 focus before I got my Vectra C, that had a similar problem, turned out to be a split hose)
    Derbyshire
    6 Post(s)
    Ive breifly checked the pipes for leaks but couldnt see anything
    no noises either(like theres a pipe off)
    It only does it when up to temp
    If it was an air leak then im assuming it would do it regardless of engine temp
    Many thanks
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Cooalant temperature sensor? If for some reason this is dodgy, it will think, at times, that the system is "cold" and overfuel/run rich. Just a thought.
    Derbyshire
    6 Post(s)
    Thanks for the help...
    I think is probably the idle vavle / throttle body housing thats causing the problem. It seems to be a problem with the 3.2 which is solved by replacing it
    Anyone any idea how much these are new...?
    Or where i could get one second hand.........?
    Back to using my trusty cav turbo till i get it sorted.......
  1. idle problem
    By speedfreeride@yahoo in forum Engine & Drivetrain
    Last Post: 6th June 2009, 19:15
  2. idle problem
    Last Post: 3rd June 2009, 00:30
  3. 2.0T idle problem
    By peteopc in forum Engine & Drivetrain
    Last Post: 24th April 2009, 19:35
  4. 2.2 16v - Idle Problem
    By SNODDY70 in forum Engine & Drivetrain
    Last Post: 24th March 2009, 09:29
  5. Idle problem?
    By dawn brown in forum Engine & Drivetrain
    Last Post: 16th January 2008, 01:50
