Results 1 to 3 of 3
Thread: vetra2.2dti sxi lipm mode again?
    edinburgh
    Default vetra2.2dti sxi lipm mode again?
    Good evening all and a happy new year to all on the forum.I have a 2004 2.2 dti sxi which has been really good but recently on long drives on the motorway or the A68 Edinburgh to Newcastle the vehicle goes sluggish for a milisecing followed by spanner light on dashboard. T turn the engine off for a secong then start again and clears the fault and power restored.Does anyone else know of a fault or experienced this to their car? your help woule be grateful
    Many thanks
    Graham
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Hi graham , you have joined the throng with this fault , common causes for this are
    1 egr valve needs decocking
    2 boost sensor needs cleaning
    3 hole in hoses between turbo and manifold via intercooler
    4 holes splits in vacuum hoses
    5 vacuum actuattor/solenoid going faulty
    all of the above could and would cause your car to go into limp mode as its known ,best cause would be to get it tech 2 ed at a dealer,s preferably with the warning light displayed to get it diagnosed get them to list what fault codes are highlighted and post the results on here someshould then b able to steer you straight
    and still loving it
    Regular Member ShauneDTi's Avatar
    Ammanford area
    I had exactly the same problem as you in the summer, it turned out to be a split hose - replaced the hose and no problems since.
  1. Vectra c 2.2dti 2003 idle mode over 75mph
    By i_am_kev in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2012, 18:29
  2. (2.2DTI SRI)‘LIMP HOME MODE’ icon. Turbo stops working!
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2011, 15:03
  3. 2.2DTI LIMP MODE + SPANNER + Engine Managment Light
    By s0501291 in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:42
  4. 2.2dti engine problems and limp mode
    By the_wave_rider in forum Engine & Drivetrain
    Last Post: 21st September 2009, 17:45
  5. Intermittent limp mode on 2.2DTi
    By Celes in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 23:12
