Thread: antenna on rear window
    Regular Member adfrodsham's Avatar
    lincoln
    Default antenna on rear window
    on my hatchback ive had an antenna since bought off last owner, doesnt appear to be any wires atached, but dont want to pull it off incase anything to do with sat nav, anyone got one on theres?
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    It should be OK to remove, as it's probably from an old Mobile telephone kit. To be sure post up a picture.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Quote Originally Posted by adfrodsham View Post
    Can you put a photo up for us to have a looksee at?
    liverpool
    Is it not for an in car phone? my dad use to have them on his company cars. That is the only time I've seen them on the rear window. HTH
    lincoln
    i can get a pic tommorow, there are no wires to it, so not sure what its for, wouldnt a mobile antenna have a wire?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Not necessarily. From what you've described it's an old mobile phone twig. The outer bit is obviously on the outside and the inner bit used to be glued to the inside of the glass covering the base of the outside twig.
    Could just be that they've left the outside bit on and removed (quite easily as it's only glued to the glass) the inner bit (amplifier box) and associated wiring.
    There were also mobile phone booster aerials, same as above but without any wiring. The teory being that your mobile transmits it's signal to the booster aerial and then to outer space or whatever.
    EDIT - you can often tell what the aerial is for by the shape of it but will need a pic for this. If you can't get a pic up, trawl through this site until you find something similar and let us know http://www.panorama.co.uk/uk/products/Catalogue.html
  1. Anyone got the VXR antenna
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 00:16
  2. Sat nav gps antenna
    By bigmac in forum Parts for sale
    Last Post: 22nd March 2009, 12:49
  3. Antenna Booster
    By Damian in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2007, 21:46
  4. Ext antenna
    By blr123 in forum General items for sale
    Last Post: 6th January 2006, 16:07
