Results 1 to 10 of 18
Thread: 100w headlight bulbs
    birmingham
    Default 100w headlight bulbs
    hi...is it possible to change the standard 55w bulbs to 100w? would this do anything to the vehicle electrics as i have bulb failure monitoring
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    They will still work as normal, no warnings etc, but the current draw will be excessive for the wiring loom and thus give you problems.
    It is also illegal to use anything other than 55W E rated lamps in the car.
    It'll fry your headlight wiring as the current being pulled will be too much than it was designed for - not to mention it's likely to get you pulled.
    I'm sure someone tried 100W bulbs and it wasn't a happy ending.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Quote Originally Posted by smartymarty1971 View Post
    IIRC 100w are illegal for normal road use (ECE Regulation 37 ?).
    Mate of mine has had one in his motorbike for 5 years. Didn't use a relay due to the extra load, just lots of copper grease on the buld terminals. To be honest, you can't really "see" any more of the road when compared to his standard 55w one.
    Belfast
    Wouldn't go with 100W, but I ran Philips Rally 80W H7 in my Corsa C with no problems at all for 18 months.
    Mileage : 000
    Don,t do it. I once had a Granada Where I put them in. They worked a treat. The head lights were aimed correctly, so did not blind anyone. I changed that motor for a Seirra and fitted the same bulbs. When I opened the bonnet, I noteced the grease on the battery terminals " smocking" due to the current draw........ Good job the wiring did not melt, It could have cought fire!!
    Regular Member mushy2007's Avatar
    Liverpool
    Do you own an extinguisher?
    birmingham
    ok...will not try...just want brighter lights without upgrading to hids...any suggestions?
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Signum 2.0 DTI (Irmscher)
    Trim : Elegance
    Engine : 2.0 DTI 100 bhp
    Bite the bullet and go for HIDS.
    Bri.
    Regular Member mat100edt's Avatar
    south coast
    i had 100w bulbs on my mk4 golf with no probs.
  1. 90w/100w bulbs
    By DeeBe in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2012, 13:16
  2. 100w bulbs
    By Rob12 in forum Electrical & ICE (including SatNav)
    Last Post: 13th November 2011, 20:52
  3. 100w H7's Headlight Bulbs
    By fifesri in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2011, 13:58
  4. 100w headlight bulbs
    By Clugie in forum Electrical & ICE (including SatNav)
    Last Post: 8th February 2010, 08:12
  5. What can be done to run 100W bulbs?
    By weston in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2010, 01:07
100w headlight bulbs in vectra c
