Thread: squeeky brakes & wiper probs
    Nov 2005
    newcastle upon tyne
    Default squeeky brakes & wiper probs
    can anyone help whats the best cure for squeeky brakes & wndow wipers that judder
    Juddering wipers.. Who's have you got fitted?? VX's own brew have never juddered for me..Some of the aftermarket one's judder like a bi#ch..
    Squeaky brakes are more common now they are asbestos free..My rears grind.. Squealing when braking can be stopped/lessened by putting copper grease on the back of the pads and cleaning the pad carriers to remove the accumulated brakedust buildup.
    Nicking Ya Dinner.
    Get some vinegar or commercial window cleaner, the clear stuff, and run a doused cloth along all the blades, should clear it up for you.
    Nov 2005
    newcastle upon tyne
    thanks chaps i will try those tips
    South East
    V/X blades do seem fine, the cleaning trick is ment to work.
    Mark my breaks grind, @ first I thought they were running low but they are almost new, can live with it just interresting that yours are the same.
    M
    Regular Member grumpano's Avatar
    North West
    My brakes are the same as well..I think most of them do it.
    Regular Member Robbieben's Avatar
    Dec 2005
    Polishing a car somewhere
    Bosch wiper Blades are fitted at factory on Uk build Models, Valeo fitted on European Build Models.
    Brakes tend to give a grinding noise when cold(normal on all asbestos free brakes) usually dissapears when brakes reach operating temperature.
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    Yep,my rear brakes are the same,might try a different pad to the vaux one to see if that cures it...
    Regular Member Marc 100's Avatar
    Nov 2005
    Berks
    My 53 plate had Bosch blades as original - they lasted 2 years before starting to smear, no judder though.
    The replacement blades from Vauxhall are now GM branded, parts guy told me that Bosch blades were too expensive hence the switch. The GM ones are good, esp at £19 a pair - cheaper than Bosch from Halfords
  1. Squeeky Brakes
    By Collis in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2011, 18:17
  2. Squeeky Brakes
    By Griff72 in forum Suspension, Wheels & Brakes
    Last Post: 29th June 2010, 18:39
  3. Squeeky rear brakes, OVERHEATING too
    By hibbsy18 in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2009, 01:37
  4. Windscreen wiper probs
    By orcha173 in forum Electrical & ICE (including SatNav)
    Last Post: 25th May 2008, 20:27
  5. squeeky brakes help!!!!!!!!!
    By stevietiger in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2006, 00:12
