Results 1 to 10 of 11
Thread: PI Springs 30mm
    Regular Member sy_uk's Avatar
    Newcastle
    Default PI Springs 30mm
    I take it i can use standard shocks with these springs until i get round to ordering shocks?
    n/s/f standard spring has snapped so convinced her i need to get 4
    All the ones 40mm+ say shortened shocks are required, but will 30mm be ok for the mean time with normal shocks?
    If so, when i can afford the shocks what ones will be best? Don't want overly harsh ride, hence not lowering it to far.
    space
    i just replaced my spring as i didnt want to compramise the ride and i lowerd it by 40 mm
    Regular Member Robbie69's Avatar
    lowered mine 40-45mm on standard sri shocks, works a treat for me.
    Newcastle
    forgot to mention mines an LS so have the bog standard suspension setup
    ah you can't lower it 40mm then, should be ok with 30 I would've thought.
    Newcastle
    hmm, came across bilstein b4s + h&r 40mm spring kit for £361, shipping will probably bring that to over 400 from france, they do it with eibach 30mm springs for €15 more
    it comes down to what you wanna spend but sure it would look good.
    Newcastle
    yeah - or how much she will let me
    I'm pretty sure the garage who is going to look at the broken spring will say the shocks need replacing
    well you may as well bite the bullet and get what you want! Just tell SWMBO there was n't much differnce in the price.
    Newcastle
    my last comment was a hint due to swmbo
  1. PI springs 45mm or 30mm
    By TimTay in forum Handling & Braking
    Last Post: 30th November 2010, 20:50
  2. PI's -30mm springs
    By Chuddy in forum Handling & Braking
    Last Post: 24th May 2010, 22:06
  3. B4's with -30mm springs
    By Lao in forum Handling & Braking
    Last Post: 23rd February 2010, 18:58
  4. 30mm springs???
    By stuee in forum General Chat
    Last Post: 2nd March 2009, 00:12
  5. New Spring -30mm or new shocks and springs -30mm
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2008, 12:51
