Thread: Fuel Pump Location
    Regular Member Signum Mad's Avatar
    Lisburn
    Default Fuel Pump Location
    Hi, just want to check. Is the fuel pump on the Signum 2.2dti located within the fuel tank?
    Devon
    100 Post(s)
    Vehicle : insignia
    Trim : irmscher
    I thought it was on the engine ? its not like the old astra gte's and that where the fuel pumps drivers rear and buzzes the diesel fuel pump is on the engine or so i believe and if i'm wrong i will eat a kitten
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Do you mean the high pressure pump? If so, then it is on the engine, just follow the injector pipes all the way down.
    Lisburn
    Not sure, I started a post on Friday describing a problem I was having. (Don't know how to add a link to the original post or I would). I have tried a few of the suggestion that the guys posted but no joy, someone has suggested that the fuel cold be draining back to the tank and therefore being starved after initial starting. So I was just curious to the location of the location.
    In case you do not wish to read my previous post I will give a brief recap of the problem.
    When I leave the car sitting for more than 9 hours without starting it i.e. overnight. When I start the car in the morning it will fire first time but after a very short time it stalls, I then have to wind it over and over and over for a while to get fuel back into it. After the second, sometimes third, attempt it will fire and run perfectly until another long break.
    This is why someone thinks that it could be the fuel draining away from the engine.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Sounds like leak off pipes leaking air to me. This is a common problem. These are the small rubber pipes and T connectors that drain fuel from the injectors that hasn't been used for 'squirting'. They leak and cause a lack of fuel to the pump, shortly after initial start - resulting in stall.
    I dare bet it is worse if you park 'nose up'
    Lisburn
    Thankfully I live on level ground. Thanks Ste for the advice, I'll try these connections.
  1. Replies: 19
    Last Post: 30th May 2012, 15:53
  2. 04 2.0 dti power steering pump location
    By melvyn8181 in forum Diesel Engine related
    Last Post: 19th August 2011, 21:44
  3. Signum petrol fuel pump location?
    By Caveman_nige in forum Petrol Engine related
    Last Post: 7th December 2010, 21:26
  4. high pressur fuel pump and fuel regulator ?
    By simplesi in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 12:23
  5. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
location of the fuel tank pump vauxhall vectra c
tank pump place opel vectra c
vauxhall vectra fuel pump location
opel signum fuel pump loacation
