Results 1 to 10 of 15
Thread: disconnecting the battery!
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    Default disconnecting the battery!
    just a quick question.
    im running a power cable through the car for an amp. and just want to make sure that if i disconnect the battery i wont have to go to vauxhall or somewhere to get stuff reset or anything like that.
    basically... will i be able to disconnect the battery for a couple of minutes without messing the car up?
    thanks for the help
    carl
    Regular Member David's Avatar
    peterborough
    I have done it and had no effect, but you will need your radio code
    nice one mate
    cheers
    peterborough
    no probs
    As David, just disconnect the -ve terminal and you'll be fine. You may also need to reprogram the windows as they may not auto open/close (keep going up/down once you let go of the button inside the door) when you reconnect. Just hold the buttons to wind the windows up but keep it held once it closes until you hear a click, then they should auto close again.
    HTH
    Regular Member pauls898's Avatar
    Malvern
    You have to disconnect the battery within 15 seconds of turning off the ignition key otherwise your wake up you nearbours, as the alarm will sound for 30 seconds lol as this has a battery backup.
    HTH
    it will be the + side of the battery if he's running power for a amp
    Malvern
    You always disconnect the -ve first for safety reasons, then as you say if hes connecting a new wire for hes amp then this goes onto the +ve terminal, making sure he includes an in-line fuse close to battery, then reconnect the negative terminal -ve last. Then reset the electric windows and enter the Radio code. Job done
    Quote Originally Posted by pauls898
    Good point.
    Quote Originally Posted by vectra 2.0 t
    You beat me to it Paul. That's what I was about to say. My reference to disconnecting the -ve terminal was for initially cutting the power. Obviously the amp will be connected up to the +ve for the power feed for the amp.
    thanks for the help guys. the amp is all powered up now.
    had to reset the windows (auto close/open), and that was it. (alpine headunit, didnt need key, just had to set the audio stuff again).
    got the amp running a pioneer 10" at the minute. until i have saved enough pennies for the alpine 15" i want.
    thanks
    carl
  1. When disconnecting the car battery.......
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2018, 14:54
  2. For those disconnecting battery with ESP!!!
    By rushy in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2007, 22:07
  3. Disconnecting the battery
    By badge25 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd June 2007, 12:40
  4. Disconnecting battery...
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2007, 23:06
  5. Disconnecting Battery
    By Neil in forum Electrical & ICE (including SatNav)
    Last Post: 21st April 2007, 18:12
vauxhall vectra c battery disconnecting
