my friend has a 03 sri 2.2dti vecy. He gets a bulb waring light up telling him that his fog light is out but its not? any ideas on a fix for this?
try re-fitting it and cleaning the connective bits on the bulb and holder.
i had the same on and off all the while untill i gave it a clean
ok ill give it a look.
no problem m8
worth doing the cheap way first.
before changing bulbs
I had the same, altough the bulb worked it wasn't seated properly, gave it a good wiggle and it solved it! It's just a case of doing each one till it's sorted.
Had a similar problem with mine it said right side light not working. It was working. But did pack up a few days later.
Had the same problem, it was the filament on 1 bulb that was making and breaking. I ended up taking each bulb out in trun, checking with an ohmeter then giving it a shake and checked on the meter again until I found the suspect bulb. Replaced it and never had a problem since, circa 2 years ago.
No I replaced the offending bulb. It was obviously making and breaking contact as the car was moving and causing the warning message up when it was breaking contact but when I checked the bulbs initially, they were all ok. The warning message did come and go though with the making and breaking of contact during the journey. It was about the 3rd bulb down if I remember correctly on the passenger rear side.
