Results 1 to 10 of 15
Thread: k+n
    wales
    Default k+n
    just a few piccys of my new k+n filter engins abit dirty but
    Regular Member Robbie69's Avatar
    looks good mate, notice anything different apart from the noise?
    Regular Member jb-redbull's Avatar
    warrington area
    Trim : half leather
    Engine : 2.0 turbo petrol
    Mileage : 149,000
    not sure if i am right im sure i am but it needs a shield between air filter and engine or it will just suck in hot\warm air from engine. is it just running from normal air box air feed as well.if it is i think from where it is it may be to far away.it does look good though mate.
    Regular Member falco's Avatar
    Jun 2007
    Cockermouth
    I have one of those fitted to my car. Added the heatshield and it does help. I noticed since fiiting the car seems to pull better.
    wales
    not got heat shield where i get one i does pull better and sounds nice it is running from normal air feed followed the instructions from the k+n leaflet just did not know about heat shield.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Looks nice mate, but it will run worse. A stock airbox with K&N panel filter will work far better than what you have there.
    Jun 2007
    Cockermouth
    Mine runs better with the cone filter than it did with the stock airbox modified. I have the heatshield and plenty of cold air going in.
    You can buy the heatshields from demon tweaks they range from £10-£15.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    looks nice m8 but i do prefur the panel filter my self
    i bet it sounds nice now
    wales
    Yes sounds good tried panel filter did not like as much as cone :-)
    Regular Member david.aka.judas's Avatar
    Suffolk
    now use this:
    http://www.espdesign.co.uk/p63020/Co...duct_info.html
    I laid the pipe under the car and had it strapped to the sump cover, worked a treat and you just have to be careful over speed bumps.
    get it nice and cold..........!
