Thread: thermostat removal help
    london
    Default thermostat removal help
    hi guys
    i've started to change the thermostat from my 2004 vectra cdti 8v when got stuck in the midle of the job.
    after removing all pipes from thermostat and top screw out ,second and bottom screw became a problem as it attached to something i cannot remove!
    question guys is:
    how to remove the thermostat without removing ""half right side of the engine" first ?
    thanks
    london
    Sorted!
    Jun 2006
    Newcastle
    How did you do it mate....
    My thermostat O ring has gone and I need to replace it.... I noticed the same difficulty... How did ya do it?
    london
    2 days to remove the faulty one, and 2 hours to put the new one back!
    you need to loose the metalic pipe that's in front of the thermostat (the one that's blocking the thermostat) by removing the screws at the back of the engine, right below the egr valve (you need to loose it aswell) .this screws holds this pipe at the back and, and after doing this pull the pipe away from the thermostat just enough to remove it! it not easy but you can do it as long you have the right tools!
    Well done that man …………… ……………..
  1. 1.9Cdti Thermostat removal
    By Cruize in forum Engine & Drivetrain
    Last Post: 24th December 2012, 16:15
  2. vectra 1.9 cdti sri 2006 120 bhp thermostat removal
    By jayhirst12 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 20:19
  3. new thermostat
    By wildchild in forum Vectra C / Signum Troubleshooting
    Last Post: 24th August 2012, 14:02
  4. cdti 120 Thermostat removal
    By wrighty11 in forum Engine & Drivetrain
    Last Post: 12th April 2012, 09:06
  5. 2.2 dti thermostat
    By Al 22 dti in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 22:29
