Results 1 to 10 of 13
Thread: Lights Flickering?????????
    Regular Member shadow-irl's Avatar
    WATERFORD-IRELAND
    Default Lights Flickering?????????
    Howdy, quick question for ye. when my 2003 gts is ticking over with the lights on i've noticed that they are diming (inside+outside)Can anyone put my mind at ease to what this could be.
    A mate did say to me tho that its a sign that the car is charging.mmmmmmmm i dono.
    Regular Member bobbyboy's Avatar
    Jan 2006
    Durham...
    theres a couple of threads about this but no answers... mine does the same its more noticeable when reversing into the drive...having said that, its only the headlights that flicker and not the dash lights etc...anyone got any ideas out there ??????
    South East
    My 03 is the same as BBoy above, almost that the alternator outputs full wack @ 800 rpms and above!
    WATERFORD-IRELAND
    Sorry guys i was a bit broad i meant outside lights + courtesy lights
    South East
    Same as, ouside + courtesy lights but not dash.
    Regular Member CDTi Mike's Avatar
    Dec 2005
    Melksham, Wiltshire
    Smile
    same here when the revs drop.
    i've noticed it in all the vecs i've driven - i've gone through a fair few hire/company vectras.
    Regular Member Ian's Avatar
    York
    alot of cars do this, especially petrols, as the battery capacity is lower than one fitted to a diesel, plus petrols have spark plugs to fire. The alternator wont kick out top current until 1500 revs, so the car is struggling to run eveything at low revs. Diesels have bigger capacity batteries so the car can use that as a reserve when the alternator is at low output. fitting a diesel spec battery may eradictate the issue. I did this on my old Cav V6 when i fitted some amps and a subwoofer and the flickering lights dissapeared.
    If this happens at low RPM when parking or driving this will be the steering pump robbing the power from the lights..It's very common and caused by the electric pump..This pulls over 80amps and so at tickover it is quite a strain on the electric system..If you've never had a car with an electric pump before it can be alarming but it's quite normal..
    Nicking Ya Dinner.
    Your car has been possessed mate, get the vicar in to sort it out with an exsorcism.
    South East
    My heated seats are pulling hard on the battery as well. Thats true Mark about the steering, that boy if hungry bit like me!
    M
  1. Lights Flickering
    By Alan/1967 in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2011, 14:20
  2. Flashing/Flickering HID Fog-lights
    By Damo77 in forum Styling
    Last Post: 24th March 2011, 11:50
  3. Lights Flickering
    By Chris SRi in forum Electrical & ICE (including SatNav)
    Last Post: 16th February 2011, 22:59
  4. Flickering Lights
    By jamesyoumans in forum Electrical & ICE (including SatNav)
    Last Post: 28th December 2010, 22:04
  5. lights flickering
    By mat osborn in forum Electrical & ICE (including SatNav)
    Last Post: 9th December 2008, 01:57
