Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Exhaust Gas Recirculation Flow Malfunction
    Regular Member H0885's Avatar
    Apr 2008
    birmingham
    Default Exhaust Gas Recirculation Flow Malfunction
    Help me please!
    My car went into limp home mode last night and refuses to come out of it.
    After putting it on a diagnostic computer the following code came up.
    Exhaust Gas Recirculation Flow Malfunction P0400
    What does it mean and how do I get it repaired?
    He's mentioned a new cat, does this sound realistic or is it soething simple?
    He thinks you need a new cat due to an EGR fault code stored?! RUN!, run for the hills!!! lol
    Seriously though, the first thing I'd look at if it was me was the EGR vale itself and there's a good chance it just needs a damn good clean - common thing on cars with EGR valves.
    Regular Member VXR CDTi's Avatar
    Jan 2008
    South Wales
    Apr 2008
    birmingham
    Cleaned the EGR myself this afternoon and the thing was flithy...really bad!
    The car is still in limp mode and I was thinking about going to VX on Monday?!
    Apr 2008
    birmingham
    Does anyone know anyone in birmingham who might be able to sort this for me?
    Vehicle : Insignia sport tourer 2.0 CDTi
    Trim : /Elite
    Mileage : 34900
    If your egr valve was cruded up did you also clean your boost sensor and the manifold it sits on , also check your vacuum hoses for leaks splits and cracking (common fault on the dti,s).
    and still loving it
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Did he reset the fault too?
    Bristol
    Default Code reset
    Hi if you have radio code the disconnect the battery. The alarm will go off fo a few sec. leave for 20 mins. This will restet your ecu to default settings. Ther saved you £50 sqid
    13 Post(s)
    Quote Originally Posted by sb1uk View Post
    Or alternately turn on and off the ignition and disconnect the battery within 15 seconds - which will then stop the alarm from sounding.
    Apr 2008
    birmingham
    Thank you all for your help.
    He did clear the fault but the dreaded car and spanner kept comming back on!
    Its going back in to the garage tomorrow for another go. Wish us luck, i'd hate for this to turn into a massive problem.
  1. P0400 - Exhaust Gas Recirculation Flow Insufficient Detected
    By lencuff in forum Y & Z30DT Specific
    Last Post: 20th November 2012, 18:15
  2. Exhaust Gas Recirculation Circuit Open
    By john norris in forum Engine & Drivetrain
    Last Post: 16th October 2012, 12:56
  3. P0400-F8 Exhaust Gas Recirculation Valve Feedback Signal Malfunction
    By Vectra Forever in forum Engine & Drivetrain
    Last Post: 30th June 2011, 15:19
  4. P0400 - EGR Flow Malfunction
    By BigMart in forum Engine & Drivetrain
    Last Post: 30th May 2011, 22:07
  5. P0400-5B Exhaust Gas Recirculation Flow Excessive Detected
    By zafira in forum Diesel Engine related
    Last Post: 11th September 2010, 07:46
egr flow malfunction
P0400 Exhaust Gas Recirculation Circuit Open C-16
where can i find the exhaust gas recirculation flow malfunction on a vauxhall astra
