so out of all the people who have fitted these who has had no trouble and which ones did you buy ??
I first got a set off ebay but not for the C, they worked well as long as you turned them on b4 the engine, Mrs couldn't understand this so I gave up and took them out. New set on the way from hids-direct but I don't hold out much hope and they will probably be on their way back by Tuesday!!!!
why did you have to turn them on b4 the engine![]()
because if you didn't they flashed and farted then went off leaving a bulb error. If you turned them on, waited 5 seconds then turned the engine on, they worked a treat every time.
you need a bulb faliure resistor,had no problems with mine,hid,s direct should be able to supply a pair of these.
i fitted them and they turned the bulbs a nice salmon pink, new set on the way from hids direct, missed the courier on Friday so I've got to wait!!!!!!! Weekend off too, typical.
