hi,i have been looking for a set of lowering spring for my vec,however no one seens to list ones for a 3.0 cdti sri only a 3.2 are they the same ?
i mean the same fitment will the 3.2 springs fit the 3.0
3.2 ones are a different weight rating. 3.0 are stronger, KW do 40mm drop for the 3.0 and they work well with bilstiens,as i have this setup .
cheers for that will give them a try
i got a full set 3.0 cdti sri eibach spring's 30mm
but only fitted the front ones
I got the set from LMF Steve
hi ian c, did you change the shocks or just the springs? also does anyone know if i need special shockers seen as i have the 05 v6 cdti, and it has the electronic stability thing fitted or can i use normal shocks? would like bilsteins. thanks tony
ESP won't make any difference - it's only the IDS+ that has special clevertrickery dampers.
Bilsten/Eibach is a great combination![]()
many thanks for your reply parapaul, thats great news, will let you know when i get them, will the bilstein b4 shocks be ok or do i need the dearer ones? thanks tony
B4's are good, B6's better![]()
