Thread: help needed LOSS OF POWER 1.9CDTI
    Regular Member vectra666's Avatar
    manchester
    Unhappy help needed LOSS OF POWER 1.9CDTI
    I DRIVE A 1.9 CDTI SRI 150 WITH 104000 MILES
    just ben out to visit grandparents with the kids and on my travels car had loss of power
    turbo statred to kick in around 2000rpm... 10 mins down round and engine management light comes on and now theres no turbo what so ever....
    drove home around 7 miles creaping at 30mph light went out just as i got home.
    taken car back aroung the block but is still low on power and turbo only coming in at 2000rpm. ONE MINIUTE ITS A SLUG THEM BAM, POWER IS THERE
    ANY HELP IS WELCOME
    Regular Member Avenged's Avatar
    Liverpool
    possibly the loom on injector no:3??
    just a thought like
    manchester
    Unhappy
    above 2000 revs when the turbo kicks in the car is smooth though?
    would this evidence rule out the injector????
    cheers for any help guys
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Quote Originally Posted by vectra666 View Post
    your symptoms are the same as my issue I had with my CDTi, took it into the dealers and they rectified it by replacing the injector loom, although number 3 was the problem.
    Feb 2006
    Guttedsville
    EGR Valve.
    May 2006
    scotland
    Try disconnecting the battery for 45 mins or so to clear any codes and if it comes back, a trip to the delears or to someone with a fault code reader.
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Quote Originally Posted by AndrewTi View Post
    EGR Valve.
    Actually Andrew you are correct, it was the feeling of miss firing when they replaced the injector loom.
    It was the EGR Valve that was replaced when it had the same syptoms below 2000 rpm no power then above it would go like a train.
    Regular Member Daywalker's Avatar
    Aug 2007
    Virbaliskiu km, Kaunas raj
    Vehicle : Astra Sports Tourer
    Trim : active
    Engine : 1.7cdti
    EGR Valve.
    :WHS: or the boost sensor
    Regular Member VXR CDTi's Avatar
    Jan 2008
    South Wales
    Unclip and take off the injector plugs, give them a blow and spray into the plug some electrical contact cleaner then clean the pins in the housing of the injector using cotton buds! Check the EGR valve coz that can get caked in soot, also give the boost sensor a clean and buy some Millers Diesel Power Sport 4 which goes in the fuel tank to give the injectors and everything a clean inside the engine!
    Failing that, do the modification for injector plug 3 by reading the threads on here, I also have a HOW2 pending with pictures of how its done!
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    Have you read the report in the Daily Mail today on this problem that is, according to the paper, only on 2.2s, it does not state is petrol or oil burner. Could be another recall looming up?@
  1. power loss on a 54 plate 1.9cdti 8v
    By alistairmaxwell in forum Vectra C / Signum Troubleshooting
    Last Post: 14th November 2012, 23:41
  2. Loss of power, 1.9cdti sri 150
    By Lee_Pike in forum Engine & Drivetrain
    Last Post: 16th May 2012, 23:08
  3. 1.9cdti judder and loss of power then fine.
    By voxvectra7 in forum Engine & Drivetrain
    Last Post: 27th September 2011, 23:42
  4. 1.9cdti loss of power & smoke
    By nrthwd stu in forum Bodywork & Interior
    Last Post: 9th June 2010, 12:52
  5. 1.9CDTi Major Power Loss
    By GlennM in forum Engine & Drivetrain
    Last Post: 22nd May 2010, 21:59
