Thread: Help! Setting up a Belkin Wireless Router
    Regular Member chrisf70's Avatar
    Mar 2007
    Cambridgeshire
    Default Help! Setting up a Belkin Wireless Router
    Hi,
    My nephew has purchased a Belkin N Wireless Router. He's asked me to have a look at it. I've been to their house and the set up they have ain't the best. They have an old NTL cable modem with USB connection to the PC. There is no network card on the PC with an RJ45 connection.
    So everything I've read about this Belkin router says that the modem it will be connected to needs an RJ45, not USB connection to the PC.
    Basically there are only RJ45 connections on the back of the Belkin router, so is there anyway of connecting the NTL Cable Modem to the Belkin router and then through to the PC with the current set up?
    Thanks.
    It should be possible. I remember my brother did this with his NTL modem and a router. I think what he did was have the NTL modem connected as normal and then set up ICS (Internet Connection Sharing) and then had the router connected to the ethernet port on the PC and the connection was shared that way.
    EDIT: Just read it again and there's no network card on the PC. You're not going to get anywhere in that case then. You need some way of the router being able to connect to the PC i.e. a network card. They're as cheap as cheaps.
    Mar 2007
    Cambridgeshire
    Cheers Duncan,
    That's just what I thought, I only work with networks and PCs with a network card! So to see a modem with only USB connection has thrown me!
    Thing is the poor kid has saved up from his paperround and got this router without knowing the ins and outs. Guess he'll just have to deliver a few more papers!
    If he's only just bought the router, can he not return it and get one that is cable compatible instead then?
    Surrey
    Sounds like an Old Modem . I had one years ago NTl then used to supply a USB\ETHERNET converter. Ask Virgin to supply their wireless Netgear router.
    Surrey
    and go for some other manufacturer too, always had problems with Belkin products.
    Quote Originally Posted by iainm View Post
    Even better! Do they supply that FOC then?
    Surrey
    Surrey
    They will probably change the modem for an Ethernet one if you phone and ask nicely. MY black modem is Ethernet only
    this would suggest your modem is obsolete and un supported so should get free replacement ethernet modem
    http://www.digitalspy.co.uk/forums/s...d.php?t=751328
    Regular Member neilshaw1980's Avatar
    Oct 2006
    coventry
    As others have said its the modem. You wont get anywhere with that modem.
  1. Belkin Play Max Wireless Router With Built In Modem
    By viper8 in forum General items for sale
    Last Post: 6th April 2011, 12:59
  2. Belkin 54g ADSL2 Modem with G Router
    By Nickzx6r in forum General items for sale
    Last Post: 4th May 2008, 15:19
  3. belkin wireless-g router
    By david-bell in forum General items for sale
    Last Post: 2nd January 2007, 12:54
  4. Replies: 12
    Last Post: 29th November 2006, 10:17
