Thread: Alpine headunit and steering wheel controls...
    Feb 2006
    USA
    Default Alpine headunit and steering wheel controls...
    I have just tried fitting the AudioLeads PC99-X06 and the PC99-ALP cables in my 53 plate pre-face lift Vectra C SRi, in the hope of getting steering wheel control of my Alpine CDE-9850ri head unit. It didn't work for me, just wondering if any other members have had success with this set up?
    Simon
    Wiltshire
    Give In Car Technologies a ring on 01420 540277. Part number 29-801 is to fit an Alpine to a CanBus Astra, but I would've thought it'd work with a Vec, too.
    edit: Might not work. Just noticed yours is a 53 (should've read the post properly!) and this interface is for 54 onward I think. This is the company recommended by Alpine anyway, so they might have a solution.
    Feb 2006
    Guttedsville
    It worked for mine, if you like I'll try and get the unit out of the dash tomorrow and see what wires go where for you. Our cars are virtually identical it seems, even down to the headunit, so I can't see how it would work for mine and not yours.
    Feb 2006
    USA
    Thanks Andrew, but don't go to any trouble... I know how much of a pain it is removing the head unit! I was a bit puzzled with the audio leads interface as to a pair of orange wires with a male and female connector on... no indication in the instructions as to what they were for! Also I thought the 3.5mm plug that goes in the back of the alpine headunit went in a bit too easy... but as you said I would have expected it to work! I wonder if its something to do with CAN bus, but I dont think the steering controls on my veccy are canbus... the old vdo 2005 certainly isnt canbus, though I did have a ncdr2003 sat nav in there for a while.
    Simon
    Feb 2006
    Guttedsville
    No probs, bud. If you change your mind or curiosity gets you, PM me, we'll sort something out next time I'm coming to see Cardiff play.
    In the mean time, John Klies of Reading fitted mine, using those leads, Maybe give them a call to see if they'll help. call 0870 770 2860.
    They did have to wire an Ignition feed to the wire that controls the wheel buttons apparently, but I chickened out of fitting this myself!!!!!!
    Regular Member Cheeky_B's Avatar
    Irvine, Scotland
    Any result on this guys I have the same problem with my Alpine Head Unit, got all the wiring kit, and cannot use the steering controls. The two orange wires are puzzling me also. No indication of where they go??
    Any help appreciated
    Feb 2006
    Guttedsville
    Bu99er. Looks like I'm pulling mine out the weekend!!
    Have you tried disconnecting the power, leaving it a bit and trying again? I read somewhere that these new units have to 'learn' about things they are connected to.
    Regular Member Draggon's Avatar
    Gloucestershire
    Well fitted the Alpine 9850 ri...sounds great
    But I have the same problem with steering controls.
    I have the PC99-X06 and PC99-ALP but no joy....Think I saw a post relating to no power to the steering control unit interface.
    Question is what wire do i wire to what?
    I have wired the Canbus interface link too the Cigarette lighter so it only works with ignition on. Thought this would be enough for the PC99-X06 loom too...evidently not
    Any ideas would be much appreciated peeps.
    Regular Member scott_150cdtisri's Avatar
    Jan 2006
    Crewe
    Has anybody got the alpine with steering wheel control on the full canbus system yet? if so how is it.
    cheers
    Gloucestershire
    Well i think AndrewSRi has and I am about too... i hope...just need advice on powering the PC99-X06
    The Alpine sounds awsome with the normal VX speakers...surprisingly.
  1. aftermarket headunit and steering controls
    By nambiker in forum Electrical & ICE (including SatNav)
    Last Post: 28th November 2011, 11:17
  2. alpine steering wheel conrol problem???
    By actionman in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2011, 16:06
  3. Replies: 1
    Last Post: 26th March 2009, 19:18
  4. What lead to use for steering wheel controls on aftermarket headunit ?
    By muffking in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2006, 15:44
