Thread: Help with 406 clutch please
    Regular Member deanos's Avatar
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Default Help with 406 clutch please
    My dad needs a new clutch for his 406 2.0HDI year2000
    Ive got quoted from Mr Clutch at £260 and Nationwide Autocentre at £540 !
    Anyone know how many hours it should take to change.
    The nearest Mr Clutch is 35 miles away but at least its a fixed price , not sure if he would be better going to a local garage, but then if it takes ages it the bill will soon mount up
    Jun 2007
    Black Country
    Be very careful with Mr clutch, they have a terrible reputation
    took my Austin Ambassador in to them years ago, I had no reverse gear as the gearbox was shot
    they said they would look at it, an hour later they come back and said it was knackered which i already knew, but the thing was,
    " they never even looked at the car"
    i was sat in the waiting room, with my car parked right outside the window
    Nicking Ya Dinner.
    Gotta be honest here, I thought my Vec B thrust bearing was on it's way out, I rang Mr Clutch for a prices, and the guy said it might be e box bearing on the layshaft and didn't want to replace the wrong thing, maybe he was just a good one, given the difference in price I'd check if the Autocentre has quoted you for a flywheel as well.
    Full Member
    Bristol
    Quote Originally Posted by deanos View Post
    Mr Clutch bristol quoted £260 but be carefull they skim the flywheel and then tell you after they have done it. So you don't no if they have or not, So if you use them make sure you say do not skin flywheel. my mate did it for £150 inc clutch mine had done 90K and flywheel was fine even thought dare I say it. It had a lady owner. Normaly use clutch pedal as footrest.
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    book time for a garage to do the job would be 7.90 hours
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    8 hours blimey thats quite long, whats a local garage charge about £40 an hour £320 in labour + £80 for the clutch around £400
    Telford, Shropshire
    Trim : Elegance
    Engine : 2.2 Direct
    I had the 2.1 TD 406 Diesel estate and it's an engine out job to change the clutch.
    To get the low stance look at the front, they rotated the engine back into the bulkhead and the local garage i use regularly say it's a real pain changing them
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Mr Clutch sounds the best bet then so far.
    What does skimming the flywheel do ? is it a seperate thing to the clutch ?
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Anyone know ?
    swindon
    Vehicle : Insignia
    Year : 2010
    Mileage : 92274
    would not take my car anywhere near mr clutch,they have a bad reputation that is 100% true,i have seen several of thier customers where the starter moters have fell off because they have not done the bolts up,they are cheap because they rush the job,you should not need the flywheel skimmed unless your clutch is down to the rivets and has csored the flywheel,a skimmed flywheel should in theory make the clutch last longer as it will be as new,but it is not a thing i would recommend you get done unless the clutch face is badly scored
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. 3.2 GSI Clutch
    By cmowen in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 13:31
  4. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
