Thread: Heater only blowing cold air
    May 2008
    North West
    Default Heater only blowing cold air
    Hi Guys, could use some advice on my heater issue.
    Car was toasty warm on the way home tonight so turned the heater to cold, now it wont go back to warm.
    Took the car out again later to see if it was a temporary glitch but no such luck. Its blowing air on all settings and the engine temp is showing normal within a couple of miles 85-90 ish so am i right in thinking this isnt the thermostat because the engine temp is ok?
    Anyone got any ideas on the most likely offending item? Im thinking its either the mixer servo, a blocked heater matrix or some kind of actuator problem for the mechanism that directs the warm air to the vents.
    May 2008
    North West
    Fixed it - the mixer servo was jammed - gave it a push and its workig again, i wont be surprised if it sticks again though and I have to get a new one.
    Mileage : 000
    Which one is the mixer servo? Did you need to remove the glovebox to get to it.
    Regular Member mat100edt's Avatar
    south coast
    if you mean by mixing servo, the control valve that controls how much ho water goes through heater (prob monted in bulk head) then you should be able to take th small stepper motor off the side of it, give it a wash through with wd40 and put it back together.
    May 2008
    North West
    Quote Originally Posted by ed taylor View Post
    Yes thats the one on the LHSide of the centre console - had to take out the glove box to get the panels in the footwell out.
    I could see the servo thing twitching when i moved the temp dial so I gave it a push and something clicked and its working again - well for now anyway.
    Nov 2009
    London
    Hello guys,
    I have same problem on my 02 1.8 petrol vectra.
    I take the glove-box out and when im switching cold/hot on the control panel i see how the red arm is moving. On position "cold" its blowing very cold air, when i switch on "not" its blowing a bit warm, but its still very cold in the car.
    I search the forum form weeks but still cant find a solution.
    Today change the antifreeze, and everything looks fine there,the pipes are worm, but still blowing cold air.
    Any advise is welcome, because im planing a trip to eastern Europe and there is freezing.
    Thanks in advice.
    p.p. The thermostat work fine
  1. Air con blowing cold
    By malcwit in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2012, 13:37
  2. Aircon not blowing cold
    By Ralphwells1967 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th September 2011, 22:38
  3. Vectra LS blowing cold air only
    By andy64 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd January 2011, 18:04
  4. heaters not blowing cold
    By andyman201 in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2010, 18:29
  5. Heater blowing cold.
    By neilgsi in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2008, 17:48
vectra c heater blowing cold
vauxhall vectra heater not blowing hot
vectra heater blowing cold
vectra c ac blows cold on one side and hot on the othervauxhall astra heater blowing cold airvectra c heater only blows coldvauxhall vectra heater only blowing cold airzafira heater only blows coldvectra c 04 heater blow cold air when on hot vectra heater blowing cold airvauxhall insignia no hot airvectra c no heatingvectra c heater servovectra c blowing cold airvauxhall vectra heating blowing coldvectra elite heater not getting hotvauxhall vectra heater servovectra c 1.9 heaters blowing cold over heating08 vectra 1.8 heater dosent blow heatvauxhall combo heater blowing cold airvectra c heater blower coldhow to fix heater vectra chow to fix vauxhall vectra c heater blowing coldvectra b 1.8 heater blowing coldvauxhall vectra 05 plate 1.8 blowing cold air
