Thread: Priming !
    Regular Member Hynzy's Avatar
    Liverpool
    Default Priming !
    Front Splitter Arrived Yesterday.
    it said that its primed, but its been primed black.
    does priming need to be a white/grey colour.
    or can i start builing up layers of colour onn the black primer.
    Maida Vale
    I've got a can of primer from Halfords that's specifically for plastics, and it's clear, so no - primer doesn't have to be grey. If it definately is indeed primed, then you can start applying topcoat as long as the surface is smooth enough already.
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    primer depends on what colour your applying and what the manufacture says. i think vx use grey primer
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Trim : Elite with sports pack
    Engine : CDTi 150
    Mileage : 103000
    When I did my front spoiler and eye brows i used the halfords high build primer in beige. Worked a treat!
    Jul 2006
    Northampton
    Trim : Sri
    Also the other thing you will need to know to get an oe paint look is how many layers of primer, paint and clear are used
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    VX use white primer from the factory, although i'm not to sure about stuff like pre primed splitters, spoilers & VXR zorst surrounds.
    Regular Member Robbie69's Avatar
    mine came white/grey from VX.
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    My splitter came in grey primer but I rubbed it down and put 4 coats of grey primer on it then let it dry for 24 hours and rubbed it down with 1200
    paper and put 4 good coats of Saphire black on and let that dry for 24 hours teh rubbed down with fine wire wool as I only needed a key for the top coat and then 4 cotas of clear laquer and let it dry for 3 days.
    Today I polished it up with rubbing compound and it has come up a treat, really pleased with the results. This weekend it will be fitted
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    imho i would spray plastic primer on it before the colour.....
    Midlands Mod Shop - NFFC.
  1. priming light brows
    By 6009tristanb in forum Styling
    Last Post: 16th August 2011, 07:43
  2. priming dti fuel system
    By andy8966 in forum Engine & Drivetrain
    Last Post: 4th May 2011, 16:46
  3. priming shocks?
    By mparks8590 in forum Suspension, Wheels & Brakes
    Last Post: 5th December 2010, 17:31
  4. turbo priming
    By andy76 in forum Engine & Drivetrain
    Last Post: 30th June 2010, 20:39
  5. Priming and Painting
    By treasure22 in forum Detailing and Car Care Discussion
    Last Post: 6th April 2010, 13:03
