Thread: Engine type
    Regular Member VECTRAMAN's Avatar
    Bridgend/South Wales
    Vehicle : 1.9 CDTI Design Estate
    Trim : Half leather
    Engine : 1900
    Mileage : 116k
    Default Engine type
    I may sound a muppet now, but does anyone have a list of what engine type goes with which code. eg X6P and so on,
    You mean the whole engine range or a specific one?
    Trim : Half leather
    Engine : 1900
    Mileage : 116k
    Not the whole range.I think mine is X6P if that makes sense. Its a 2006 1800 sri, wondering what BHP it is and for future ref to order parts.
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    I believe the engine code for yours will be Z18XER, which is the 1.8vvt.
    This iirc is 140bhp
    Maida Vale
    If it is indeed the VVT then here you go:
    Engine Specification
    Engine, location
    Front, transverse in front of axle, 7° 50' forward inclined
    Cooling system
    Liquid, sealed circuit
    Cylinders, number
    4
    Bore (mm)
    80.5
    Stroke (mm)
    88.2
    Displacement (cc)
    1796
    Compression ratio
    10.5 : 1
    Engine, type
    In line; 5 main bearings
    Cylinder block/ head material
    Cast iron/ aluminium
    Camshaft(s), location
    2 overhead (DOHC), driven by toothed belt
    Valve train
    Bucket tappets
    Valve, arrangement
    V; 4 per cylinder, variable valve timing
    Valve, adjustment
    Mechanical
    Fuel system
    Sequential multi point fuel injection
    Ignition system
    Electronic ignition map, EST & knock sensor
    Fuel pump
    Electric, in tank
    Emission control system
    Cat. conv. with 2 oxygen sensors
    Output (kW/hp CEE at 1/min)
    103 / 140 at 6300
    Specific power (kW/l; hp/l)
    57.4; 78.0
    Max. torque (Nm at 1/min)
    175 at 3800
    Specific torque (Nm/litre)
    97
    Mean effective pressure at max. power/ max. torque (Nm/litre)
    1092/ 1225
    Average piston speed (m/s)
    18.5
    Engine oil, capacity (l)
    4.5
    Cooling capacity (l)
    6.9
    Battery 12V, capacity (Ah)
    44
    Alternator 14.2V, capacity (W)
    tba
    Max. service interval
    20,000 miles or 1 years
    Emission compliance
    Euro 4
    Trim : Half leather
    Engine : 1900
    Mileage : 116k
    Thanks for the info all
  1. Road Biking......non-engine type
    By Ben_ in forum The 'Off Topic' room
    Last Post: 28th February 2012, 14:42
  2. What engine is in a 2007 jaguar x type,S class 2.0 diesel?.
    By felixx in forum The 'Off Topic' room
    Last Post: 10th September 2010, 08:12
  3. 2.2DTI Engine type
    By kenno31 in forum Vectra C / Signum Troubleshooting
    Last Post: 11th May 2010, 22:47
  4. Engine type Pics added
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2009, 19:36
  5. Engine type
    Last Post: 27th April 2009, 14:03
