Thread: faulty temp gauge ?
    market rasen
    confused faulty temp gauge ?
    for some reason the engine temp gauge seems to be acting odd since the ecu failed last year,it can take upto 30 miles for the temp gauge to move and then sometimes it goes up to 90'c within 10 minutes,then sometimes it will drop back to 70'c or even 'cold'any idea what this could be ?
    Full Member Big Sig's Avatar
    Thermostat?
    market rasen
    could be but its been into the dealer twice and still no luck must be these college leavers they keep employing !!
    Well I would suspect two things, the thermostat or the temp sender
    market rasen
    looks like im going to have a battle on my hands my cars got 61,000 miles on the clock and warranty runs out at 60,000 or 3 years and ive had enough of this damn car !
    If it was/is a problem before the warranty ran out and you had been in and out with the fault then they should treat it as an ongoing case. If not then replace them yourself. Easy to do and not that expensive.
    Full Member
    Bristol
    Default temp
    If you car is a diesel in this weather . Thats normal. I have an omega 2.2 dti and a vectra 30 cdti and they are both the same. if it petrol then yes it may be the therm.
    market rasen
    yep mines the 1.8 petrol,sounds like it could be the therm,thanks.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Our 2.2DTi takes ages to warm up now. It's almost certainly a faulty thermostate, because my old Veccy B 2.2DTi warmed up after about 10miles. Tepmeratures below 5°C. My 3.0 is just fine for now
  1. Faulty boost gauge..
    By Steven in forum Vectra C / Signum Troubleshooting
    Last Post: 15th April 2012, 21:34
  2. signum 2.0t coolant loss and faulty temp gauge
    By catbic in forum Engine & Drivetrain
    Last Post: 25th July 2011, 09:42
  3. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  4. Mini LCD Fault Display is faulty (in RPM gauge)
    By RMillerin in forum Electrical & ICE (including SatNav)
    Last Post: 26th April 2009, 22:04
  5. Faulty Temp Gauge??
    By greg in forum Engine & Drivetrain
    Last Post: 3rd January 2007, 02:11
temperature gauge on vauxhall vectra faulty
vectra 2.0t temperature gauge issue site:www.vectra-c.com
Tags for this Thread
